IRQ NOT LESS OR EQUAL TO is usually due to erroring RAM.
What kind of RAM are you running?...volts...speeds...timings?
i've packaged mine back up (my new one i got) and am planning on returning it...Quote:
Originally posted by CandymanCan
Im using a 512mb pc4200 ADATA HyperRam stick. Last night it ran Memtest86 for 15 hours continusly without 1 error @ 279mhz. 2.9v . Yet i still get error's in windows.
Timmings are the stock 3-4-4-8-1t.
Iv tried 250mhz and it still gives me problems. Even tho memtest86 is fine. Same with prime95
My pc3200 512mb samsung stick does the same thing. It has to be the motherboard
EDIT: it cant possibly be my memory. I just ran 260x10 the memory was @ 100 so 130mhz and still failed prime95 after 16 minutes like it usually does.
I really do feal like taking my board and breaking it and setting it on fire. Cuss im pissed off.
i have a shuttle an50r but i can't get it to work :(
so basically i'll have an idle a64 system until i can get that dfi board... sigh
yeah, i get same blue screen even when running 240 mhz with the 166 divider putting my ram at 200 mhz and i get all different sorts of BSOD errors, one being the IRQ driver error...
anyway... stupid epox board...
i got these messages all too:
pnf list corrupted - u put the ram in different slots put it in that one which worked first and it ll do again...
irq less or... - is a driver problem any of ur driver couldnt get stable @ the htt or that speed maybe u didnt set agp 67 ?
but irq nor less than equal is driver problem
in ur case its one in system/32 so i think it s your video dirver try setting the agp to 67 - 69 mhz
htt on this board is rockstable @ 275 x 4 so.... neednt to change...
seEn andL
Bigtoe said it will be around the same price as the Lan Party nForce2 board. $120 - $130. I wish they would make a stripped down version like with the 8KDA3J. I just don't need all of the extra crap.Quote:
How much will the DFI board be and when will it come out. ?
I only get one error every now and then and it's in the same file C:\DOCUME~1\Jason\LOCALS~1\Temp\WER4.tmp.dir00\<b> appcompat.txt</b> always this one. Could some one please possibly tell me how to fix this prob? also which BIOS fixes the Vcore bug mine jumps from 1.808 idle to 1.9v under load
I'm using BIOS 5/5/04
@ gamer512
maybe this is a virus because which important data should be in the temp file?
or what is this file for app....
and @ candyman
NO i definetly dont mean change driver s (u could try) but i wanted to say that maybe u should set the agp fix on 68 or 69 becuse if the message is irq nor less than... then its a driver problem and in ur case this was also caused by the system32/ati driver (vga driver)
i wanted to say maybe agp lock didnt work well because of ur settings?! (normally it is 67 or 66 i think....)
so check out playing some with this ? :D
seEn andL
Yeah I tried deleting the files but it still occurs. Also mostly when I play OpenGL games does this happen the most.Quote:
Hmm that problem soundsl ike something the temps folders.
Have u deleted to temp files in there before ? Try deleting youre temps files and go to disk cleanup and delete all the junk in thier, also it wouldnt hurt to delete youre cookies also.
ok man check this out!
get latest anti virus...
get ad-aware....
get spybot search & destroy...
get... cw shredder...
download free versions searching in google...
then restart system and start save mode (win) then go to the systemrecovery (sry 4 my english m8 :D )
and turn it off....
because some of this :banana: :banana: :banana: :banana:ty virus r starting with windows and the sys recovery always restores them.....
then run all these programs and then restart in normal mode and set the system recovery again @ on :D
this should help ya...
seEn andL
amen this board sucks...Quote:
Well an update. No go failed prime95 like sually. and 279x9 still gives me blue screens.
Gues i just have to stick with 250x10 for now.
This motherboad sucks. Waist of $99
Gamer512, how are u able to get past 2500mhz. It seems anything i do my comp is stuck @ 2500mhz using stock voltage 1.55v 2 mhz higher and it failes prime95 even with 1.85v
Temps are 31 idle and 43 load.
Also ANDL64, if its a driver problem how am i ganan fix it. I treid the 67-68-69 agp mhz still no go i tried diff ati drivers no go.... Sniff this sucks
its running fine at 2.1 ghz but anything higher than 2.3 and i can't do anything...
so i'm returning my other one and will have to either patiently wait for the dfi board or get the chaintech one as a temp.. :)
Well on stock cooling and stock volts my CG 3000+ does 2.52 prime stable 33c idle 45c full load and even if I gave it 1.7v on stock cooling it only gave me 2.55GHz. It was a heat issue. When I got the temps down to 20c load with 1.9v it can do 2.8-2.82 prime stable. So you just need better cooling.Quote:
I thought that too but with everything stock I don't get any errors. I narrowed it down to some kind of issue with my ram it seems. I might try another bios but I'm not sure if that would help.Quote:
Originally posted by andL64
@ gamer512
I think I solved my problem also I set my AGP to 70MHz and put my memory in the 1 & 2 slot insted of 1&3 like I had it before. It seems to be running fine 2.8GHz 233MHz 2-2-2-5 T1 kind of weird
1 closest to the CPU, let me know if 75 MHz helps more?Quote:
What is the 1 and 3 slot and 1 and 2 slot.
? The one closer to the cpu or the middle one or the one closer to the vdimm mod.
Also im not using stock cooling im using water so it isnt a heat issue
Edit: I tried that 70mhz for the agp. Wow now my cpu failes prime95 after 23 minutes insteado f 16 all the time. Thats a start, Im ganna try 75mhz now
Well, I installed the 3700EB and there was no improvement except I can run 10 x 240 with tighter timings than with my A-DATA PC4200. I think my chip's crapping out rather than the board. I may take of the IHS to see if I can squeak out some more performance.
... well the motherboard doesn't have a memory controller right. ;)
Originally posted by aldamon
... think my chip's crapping out rather than the board. I may take of the IHS to see if I can squeak out some more performance.
Indeed. I think because I'm at my chip's limit it's not tolerating a higher HTT. I can run 300+ in Clockgen if I drop my multiplier and chip speed.Quote:
