well thats one hell of a first post there Tony;) welcome!!!!
Tony that setup is BRIGHT! :D
offtopic....acid can u pm me saying if ur perm banned and what for from EOCF? cos im currently banned aswell - ps i think a mod has messed with ur sig making you look stupid (unless it was you :P)
Hi !!! The systems posted in this thread are simply amazing.. here is my noobie entry to h20 cooling.
Opened
http://img.photobucket.com/albums/v3...ase_opened.jpg
Closer View
http://img.photobucket.com/albums/v3...just_about.jpg
In the Dark
http://img.photobucket.com/albums/v3...ase_closed.jpg
D-Tek Whitewater with USMA, Eheim 1048 and Unpainted Pro Rad.
Great setups .. Just browsed the whole thread.. :)
Im gona be moving to water in the coming months I think..
tahuru realy nice setup, which case is this? is it chiftec?
tnx
Thanks LittleDevil ...Quote:
Originally Posted by LitleDevil
Its an old Antec AMG1000 Plusview.
http://img.photobucket.com/albums/v3...EW1000AMG1.jpg
finally got myself some pics of my rig
http://img143.echo.cx/img143/9205/hpim0579s6qm.jpg
Whitewater, Aquaextreme 50z pump, 2-302 heater core, res, and 6 120mm fans. Keeps my cpu at around 22 idle and 32-35 loaded.
Originally Posted by THunDA
dude water will take you to the next level... :toast:
your rig is already friggen amazing put some water on er :slapass: and see what she can really do...
here is my old rigg http://www.home.no/smy/dataromme/IMG_1008.JPG idle 22 load 29-30 on winnie 2,8ghz 1.8vcore
ยจ
got a second pump-unite for increased flow and need a new gfx block
Originally Posted by aCidbAbY
Thanks man..
Im just trying to recoupe from all the cash I spend recently and in the waiting time im just reading up and learning about water cooling.. but im sure its gona happen..
:banana:
My Thermaltake Big Water in Alienware Area 51 Predator Case
http://i2.photobucket.com/albums/y25...rInstalled.jpg
Installation pics
http://photobucket.com/albums/y25/mj..._CPU_Block.jpg
Originally Posted by Thomas FJ
Nobody wants to commet on my setup!? :(
Or are you just too envious!?! :D
/Thomas
Just woundering why you decided to go Pump>GPU>CPU>Rad>Res. I guess it don't really matter, but I would have ran it like Pump>Rad>CPU>GPU>RES.
Hmm, haven't thought of that before... But then the pump have to stand normal, and I have to use a L-piece before the inlet...Quote:
Originally Posted by spatman
Wouldn't it be best to keep it like it is now then?
/Thomas
That is totaly up to you! It looks great, what Iwaki you have?
A MD15-R like my sig says :DQuote:
It's totally silent, but very powerfull!
/Thomas
I have the Iwaki MD20RZT and made a custom res for it. The inlet of the pump is mounted right to the side of the res for max flow.
Cool! Any pics? :)Quote:
The way my setup is now, the water is also be pulled down by gravity, which also improves flow :)
BTW: How noisy is the 20RZT?
/Thomas
The pump has that motor hum, but my case fans are louder. Here is a Link to that res I made.
How many db(a) do you think it is?Quote:
Very nice system you got there! A monster core with weapon shroud and panafloes :woot:
/Thomas
Well I would have to guess less than 35db, but I'm not a pro at that. I can say that the noise is not irritating.
Get gel-type Heel pad @ drugstore. Stick under pump. No transmitted pump noise or vibration :banana:
Hmm, my english isn't that good :)Quote:
Originally Posted by mad mikee
Explain further, please :)
/THomas
they are inserts for your heel for your shoes :p:Quote:
Dr. Schols to the rescue!! Dr. Schols gell inserts!
dunno if they sell them in denmark... here they are at all the supermarkets and drug stores.
