Appreciate if batch info is given.
TQ
L311B286, MALAY ;)
watercooling, delided with CLU on chip.
L310B491
5ghz 1.22v
http://i.imgur.com/0jZ3uZW.jpg
http://i.imgur.com/i1vqiV0.jpg
very nice :)
5GHz 1.22V...
Wow that chip is a Malay, Vivi? Doesn't seem to be very obvious which one is better. I was waiting for Costa Rica chips to surface but some people seem to be doing better here with Malay.
L306 seems crap. needs 1.24V for 4.3GHz and 4.4GHz isn't stable at 1.280V.
I7 4770 Batch L312B323 Malay
so far 4.5 @1.28 Cpu Temp is 28.0C watercooled cpu with Raystorm cpu block and Ek360 and D5 Pump on Asus Maximus VI Gene.
Motherboard temp is 29c Memory is Gskill F3-2400C9Q-16GTXD 16 gig kit only 12 gig in 3 sticks ,,, 4th Stick was DOA being Rma'd,,,
I hope this helps and im running with a 125.0 Mhz Strap with 36 multiplier and memory is at 1187.1 Mhz in cpuid its like ddr3 2330 or something not the full ddr3 2400 with the 125 strap on but as close as i could get it without going over...
hope this helps willi...
btw i never thought about going mATX till i started looking at this board alittle more and more... but i will not look back and do not regret it.. this board has everything i want and can do sli if i choose later on....
Forgot to post... Highest Recorded Temps Were 88 on the 1 core the other Cores Were 85-86 to Mid 70's with all threads @100% tested with Aida64 Stability and SuperPI for Stability with no problems showing and tests ran over 3-4 hours each
Hello
Willip90 what is your setup in bios please ? i delided my 4770K and i have 4.5Ghz for 1.28750V but whitout HT
4770K @48*100 4800 just put the multi to 48 on al 4 cores . all volt on auto ca 1.29 and saved ASUS Maximus 6 Gene bios 711 watercooled. temp idle 30 full load under prime 68-70
my first L310B491 died and got this back from rma
another L310B491
http://i.imgur.com/I2Ykntc.jpg
Thanks sir!
This is my last bragging post, next will be serious ln2 runs,
4c 8t 1.191v (DMM) 3dmark physix test (L310B491)
http://i.imgur.com/CXk0xfp.jpg
most everything is set to auto the Multiplier is set to 36 with the strap 125 puts it up that high to 4.5 the memory i had to manually put to like 2335 i think it was and ht was on and virtualization techniology was on , Adapative was Disable as well as spread spectrum For VRM and Cpu both,,, Speed stepping was Disabled , the Multiplier and load was spread this was done not just for one core as i dont think it would be legit if it wasnt.. Rapid Start was enabled and Cpu Power duty control was set to Tprobe not Extreme. Ai Overclocker was set to manual and most all other settings were auto.... i havent really dug into it too deep to push it any further im pretty sure i could but i want to do it after i get the one stick of ram rma'd and i been thinking bout moving up to the Formula VI as it does have the watercooling option stock... if you need or want to know if anything specific was done other that that just ask as i havent dont too much to it to get it this far very little actaully.. Willi
Thanks Willi
Anyone know, how this batchs ; L313B986 - L315B340
Yo guys,
I ve got this one:
http://abload.de/thumb/batchasst7.jpg
It runs stable 4400Mhz@1.265v.
What you think about it and how high can I oc it probably under water?
New chip,on water,not the best water loop,1.118v 4.5Ghz and 4.5ghz uncore,4 cores and HT enabled
will test 5Ghz,please be 6.5Ghz on Ln2 :rolleyes: Batch L309B091
Attachment 131203
Sorry forgot,updated post with batch ^^
