jumper upside of star button & reset are LN2 MODE and is also knowed
I found a couple of "bugs" in bios.
- Changing CPU multplier always enables EIST,
- Having all unneeded onboard devices disabled for benching, loading my daily 24/7 profile in OC Profiles makes the systems hangs,
-The board seems to have a mind of it's own about choosing first boot device,
- Full screen logo enables whenever it feels like it even though i always have it disabled.
All minor flaws, i had with both bios 0078 and 0903.
Beside that i really like the board.
No i mean 0903, downloaded from official Asus site:
http://support.asus.com/Download.asp...+GENE&p=1&s=39
I had it with bios 0903, then flashed to bios 0078 and experienced the same. Doesn't bother me that much but it would be better if those "bugs" weren't there. Especially the lockup after changing profiles is annoying and takes a shutdown and bios reset to recover. Going from my daily settings to my SuperPi 32M profile works fine, switching back makes it lock up everytime, the second i hit the yes button.
thanks friend Fernando kindly did it for me i will try soon
btw to all my friends and ppl i know visit this thread :)
http://www.xtremesystems.org/forums/...63#post5120863
Andres why don't check this maybe was that you wanted
http://kingpincooling.com/forum/show...&postcount=319
I almost bought this but they did not have it in stock so went with a P8Z77 M Pro, my heart still craves the GENE...
new BIOS for M5G
http://www.asus.com/Motherboards/Int...GENE/#download
MAXIMUS V GENE BIOS 1101
1.Improve Improve system stability.
2.Enhance compatibility with some USB devices.
3. Fixed Nvidia GTX 680 hang when runing with UEFI driver.
4.Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us
So go ahead will try it also !!!
Sergio
Updated to new BIOS 1101 all works fine till now nice new features to boot, like rapid boot, new logo of ROG and 0 seconds on menu to post will keep testing and report back
ROM RAID not updated still
this is the new logo sorry the bad quality
http://i.imgur.com/qNaSx.jpg
Cheers to all
Sergio
You sure it's 1001 Sergio? I just downloaded 1101 from the official Asus site, still a bit reluctant to flash it. Do you think it's worth it?
He meant 1101, like he said few posts back.
It's working just as good as previous, but so much quicker boot, thanks to some great new features. :up:
Sergio, is it working good for you too?
So f.u.c.k.i... great andres! thanks by the links
anyone knows why with this bios new ( 1101 ) the system come fine to 4,9 Ghz and more beyond need much ,much vcore to hit 5 ghz! ,anyone any idea? for example 4.9 Ghz 1.48 PRIME & OCCT etc stable ( 3570k ) and for 5.0 ghz give me 1.56 Vcore !!!!!! When before just run with ...1.48 vcore...I don't understand...any help?
same 3570 k here costa rica batch 3214C618
Just the normal one. I don't have a raid array, i'm running a single Vertex 3 for my OS.
Hi guys I just bought a gene and my MB is not working as it should. It came with bios 813 and I ended up updating to 1101 so it aint a bios related problem.
I think something is really wrong with the voltage regulation and I'm also afraid that it will endup killing my cpu... So at default it will boot up to windows but randomly shutdown, even with 0 load, out of the blue, and boot up again... temp are at low 30s so it's all good. Though voltages are not, while watching them with cpu-z they will.jump up as high as 1.36v which is just stupid for default settings... choosing 1.36v for my usual overclock will endup having the board feeding over 1.5v on bios... and it will shutdown just after windows logo.
M4E was a smooth experience but sadly I told myself I wasnt gonna buy asus anymore after all the troubles I had with their :banana::banana::banana::banana:ty rma... seems I ended up.doing another mistake... my previous asrock wasnt thr best board in the world but not as :banana::banana::banana::banana:ty as this
