What I want to see is a 20,000RAC..If possible it will take a LONG time to get there but we all need to have out\r goals! :D
Wow I can't believe the points my 2600K is racking up these days.RAC of 8298 ! I guess it like's doing CMD wu's.:D It doesn't hurt that its running at 5008 mhz either.
Mine too has been crunching at 5.0Ghz for ~3 months now. cores are 64-68°. No issues whatsoever.
I had to stop temporarily, but expect to return to the list soon.
Latest snapshot :chicken:
I need a few more days for RAC to catch on my 980X but I'll be back in soon :-)
After being offline last week for a couple of days with a component failure I'm finally just starting to see my RAC inch back up. Hopefully can get each system back near 7000 again....
Going sooooo slow though
Both rigs are running smoothly now, added my dualie and updated my 990 which was down for 2 weeks for a failed SSD and motherboard change......
Boy you got that right..Almost 100F here at 11:27am..WCG is off till tonight when the temps drop.
Between the electrical cost of running 3 AC's and the machines pulling a constant 1200W but the biggest issue is the heat dump into the upstairs of the Beast.
With it off I can maintain 84-85F here, with it on the best I can do is 89F in the house and that is too frigging hot for me.
Once we get out of summer I'm going for that 20,000RAC..:D
You guys all seem to have heat, whilst here we have had weeks of rain. It is still warm only (17° C) , but when it does dry out I will need a machete and pith helmet to fix the garden.
Another week should see the 3770K overtake the 2600K....or will it? There is so little difference between the two on most projects that the only gain is in power use....and that too is not huge.
Dave, Buy a MOAF! It could move around 8,000 cubic meters of air an hour out of the house.... Just don't close the other windows and doors or it will suck the roof in :D
If you are not convinced about bringing in warm air from outside....think of the wind chill factor.
Well my 2600K is out of the running. Harddrive crash screwed up my hostid's RPC and I can no longer report to its hostid. I am retiring the machine because of it. Well it will still be my main gaming rig but it will no longer run WCG. You can remove it from the list (its at the bottom).
Stupid WCG and not supporting BOINC's merge profile feature. Piss me off.
My 2600K windows crashed..... running temporary for now but will move it to linux soon. That is it for current machine stats
Pussies!!! http://img502.imageshack.us/img502/1184/103ym.png
Uploaded with ImageShack.us
99F inside right now. Unfortunately I only looked at my checking account balance and not the weather report before lighting off all my rigs. :(
I had another post all ready to go with details and temps of my rigs. Lost the data in another search. :( Core temps range from 65C on 2600s with Trues to 80-85C on water-cooled and air cooled IB3770Ks @ 4.5- 4.7 :(
Damn that's hot! :S
'It's not what you've got, but what you do with it' :hm:
