what about subtests? if you do a full run can you also see the subtests. from screens provided it seems not
I have 4 min left of this damn dl and hopefully it will work. I have fancy raid and a single raptor to test on. I disagree with you there my friend. would it be sad because of pci clocking on a raid set would impair the vga? I can see why in a typical 3d bench scenario and when you have your pci-e bus clocked and how you would have to lower that clock to ensure the raid card is stable but then again. game loading in 3d on a nice raid set go hand in hand. if this is a gaming bench mark then why wouldnt they add extra points for a fast hdd setup? it sorta makes sense to me. i'll check it out.
http://i239.photobucket.com/albums/f...smith/3858.jpg
does this look right?
single gtx 460 msi cyclone 768mb
ok, did performance and xtreme presets with my two trusty 5850's 2gb each(880/1135) and 980x @ 4.25ghz~
http://img823.imageshack.us/img823/9...rformancew.jpg
http://img232.imageshack.us/img232/2378/xtremef.jpg
I thought dx11 = no LOD?
CPU/combined tests are not very strenuous huh? Im running 4.75ghz on air for them with ht 980x :confused:
P7512 580 @ 1000/1050
980x 4.75ghz ram 7-8-7 2050 uncore 4ghz
I hope you guys put a signature in each press copy and you're able to trace who breached NDA;Quote:
Obviously online service is not yet enabled. Someone leaked the copy that was provided to the press...
this sucks :(
Something odd going on here.
I'm getting the same scores with single and dual cards in SLI.
I am using 260.99, don't have 265x driver to try.
BTW
Online scores are working for me now.
Links are dead.
Thanks anyway it confirmed what i was seeing.
I downloaded the 256 driver from Nvidia, said i had a quatrro.
Used the inf from 260.99.
Seems to have worked
If you preordered your download is now available, seems to be identical to the leaked release:
Hello,
3DMark 11 has been released and can now be downloaded. The URL and the login details can be found in the email that contains your registration key.
The first time you run 3DMark 11 you will be asked for your Advanced Edition upgrade key from your pre-order confirmation email. If you skip this step you will only have access to the features in the Basic Edition.
If you have any problems, please see our support pages at
http://www.3dmark.com/3dmark11/support/
Once again, thank you for your purchase.
Futuremark Corporation
920 (21x200) & stock GTX480:
4c/8t:
http://img.photobucket.com/albums/v2...1_HT_P5358.png
4c/4t:
http://img.photobucket.com/albums/v2...1_4C_P5295.png
4c/4t + physX:
http://img.photobucket.com/albums/v2...hysX_P5298.png
^^^ I hate you... :p:
820Mhz:
http://3dmark.com/3dm11/1654
http://img30.imageshack.us/img30/9669/820mhz.jpg
850Mhz:
http://3dmark.com/3dm11/1927
http://img837.imageshack.us/img837/6114/850mhz.jpg
Pure gpu power bench, thanks Viss ;)
Now look at this ... Score from Advanced version done by my friend, and my score done with Basic. Why in Advanced Max Af Anisotropy is set to 2, when in Basic is set to 1 ?
http://3dmark.com/3dm11/1889 ---> set to 2
http://3dmark.com/3dm11/2624 ---> set to 1
it still doesn't detect cpu clocks correctly, same thing for gpu clocks and even memory o_o
http://3dmark.com/3dm11/4863
http://3dmark.com/3dm11/4947
SLI / CrossFire
On
Memory
0 MB
Core clock
100000 MHz
Memory clock
130000 MHz
its over 9000mhz ! :D
My values:
Performance Mode, Benchmarks only.
For me, it's the ugliest Bench ever. :D
Helli
http://img51.imageshack.us/img51/2130/3dm112.jpg
P 9105 Quick run on daily OS drive. 920 @ 4.3ghz 2x5850's @ 1050/1225 10.4 drivers:rofl:
From Hardwarecanucks:
http://www.hardwarecanucks.com/forum...-review-9.html
Processor: Intel Core i7 920(ES) @ 4.0Ghz (Turbo Mode Enabled)
Memory: Corsair 3x2GB Dominator DDR3 1600Mhz
Motherboard: Gigabyte EX58-UD5
NVIDIA 263.09 WHQL
ATI 10.10 WHQL
http://images.hardwarecanucks.com/im...GTX-570-92.jpg http://images.hardwarecanucks.com/im...GTX-570-91.jpg
Note: the chart above shows two GTX 570 cards; the upper one should read GTX 580. We are in the process of doing the necessary revisions.
6850 crossfire
6116p
http://3dmark.com/3dm11/7302
GTX 460 @940/4600MHz
Q9650 @4.00GHz
Forceware 260.99 WHQL
Graphics Score
http://img34.imageshack.us/img34/4907/new28.png
http://img9.imageshack.us/img9/6785/...0715001240.jpg
http://img109.imageshack.us/img109/3...0717191569.jpg
http://3dmark.com/3dm11/750
http://3dmark.com/3dm11/4542
