can anyone help with some pictures illustrating the obsidian 800D case led change!i would like to replace them with red ones but it would be nice if there were a lil tutorial regarding this! :) newbie alert :)
Finally done with painting my 800D! Check it out.....
http://i457.photobucket.com/albums/q...D/IMG_0839.jpg
http://i457.photobucket.com/albums/q...D/IMG_0835.jpg
http://i457.photobucket.com/albums/q...D/IMG_0837.jpg
http://i457.photobucket.com/albums/q...D/IMG_0833.jpg
looks nice! Sparkly
Shiny! Looks great! :D
Love this case :D
very nice clean looking setup. Now just sleeve the 24pin ;-)
I'm trying to figure out an easy way to mount the rad grill->fans->rad (from the top). I might have to cup screws with a dremel, because so far, haven't found any that will do the job. Included screws with the MCP320 are too short.
My system:
Build
Case..........Corsair Obsidian Series 800D Full Tower
Mobo.........EVGA X58 Classified3
CPU...........Intel i7 920 D0
RAM...........Dominator GT 6GB 3X2GB DDR3-1866
PSU...........Silverstone Strider Plus 850W
GPU...........PowerColor 5870HD
HDD...........Dual OCZ Vertex2 120GB SSD RAID0
Sound........Creative Sound Blaster X-FI Titanium FATAL1TY Champion
Cooling
Radiator.....Swiftech MCR320-QP Triple Radiator
CPU...........EK-Supreme HF - Nickel (Plexi)
Mobo.........EK Waterblocks EK-FB EVGA X58 Classified - Nickel Acetal
Reservoir....iandh SteathRes 225 Multi-Option Reservoir
Fans..........Coolermaster R4-L2R-20CR 120MM Red LED
Pump.........Swiftech Über MCP-655 (matte black finish)
Sleeving.....MDPC-X Black+Red
Tubing.......PrimoFlex 7/16" ID 5/8" OD Red+Black Tubing
Fittings......Bitspower Matte Black Compression
Coils..........PrimoChill Anti-Kink Coils - Gloss Red
Dye...........Mayhem Red with Silver KillCoils by iandh
Thermal......IC Diamond 7 Carat & Arctic Silver Ceramique
Bays
Fan cont....Lamptron FC-5 V2
Optical......LG Bluray (with Lian-Li besel)
Sorry for crap lighting... meter had no battery left and no replacement with me here, so had to use the trial and error approach :(
Will post more next week (on white background) and the case as a whole.
http://www.darkbrush.net/img/Stendha...ct/sp-fin1.jpg
http://www.darkbrush.net/img/Stendha...ct/sp-fin2.jpg
http://www.darkbrush.net/img/Stendha...ct/sp-fin3.jpg
http://www.darkbrush.net/img/Stendha...ct/sp-fin4.jpg
http://www.darkbrush.net/img/Stendha...ct/sp-fin5.jpg
http://www.darkbrush.net/img/Stendha...ct/sp-fin6.jpg
took som better pics than the old ones :) sorry for the dust :P
http://www.sweclockers.com/image/gal...nal&k=97a39adc
http://www.sweclockers.com/image/gal...nal&k=01c948a7
http://www.sweclockers.com/image/gal...nal&k=4f3625a9
http://www.sweclockers.com/image/gal...nal&k=f334383e
Hi, this is my Obsidian:
Dark&Light Project:
Obsidian 800D
Hardware:
-MoBo: GA-X58A-UD7
-CPU: i7 950
-RAM: Dominator GT 3x2 1600Mhz C6 @ 1500Mhz
-VGA: SLI Zotac GTX570
-SSD: Ocz SSD Agility 60Gb
-Storage: 2x Seagate 500Gb 7200
-BackUp: Lacie minimus 1Tb USB 3.0
-PSU: Corsair HX850W Mod
-Case: Obsidian 800D
Liquid Cooling
-Pump: 2x Laing DDC 355
-WB Cpu: EK WB Supreme HF Acetal Nickel
-WB Vga: 2x EK Fullcover GTX580 Nickel + Plexi
-WB Mobo: EK-FB KIT Nickel + Plexi
-WB Ram: MIPS 7' Corsair limited edition
-Reservoir: XSPC 2 Laing dual 5.25"
-Rad: EK XT 360 + EK XT 240 + EK XT 120
-Fan: 9x Enermax Cluster 120 + Noisblocker PK-1
-Fan controller: Lamptron FC5 V2
http://www.xtremeshack.com/immagine/t75055_img-7648.jpg
http://www.xtremeshack.com/immagine/t75056_img-7649.jpg
At the moment i have only this photo ;)
^ very interesting build.. it'd be nice see more photos :)
I just got a 800 D :) I'm loving it so far, got a killer deal on it. More Pictures of water setups Please.
Also i got it cheap due to the front door not closing all the way, where can I get a new door for cheap?
This is my first message and my baby :)
http://img690.imageshack.us/img690/2286/img03651.jpg
http://img683.imageshack.us/img683/8346/1gbu2.jpg
http://img194.imageshack.us/img194/1033/5img0332.jpg
http://img340.imageshack.us/img340/6715/2img1863.jpg
http://img153.imageshack.us/img153/1567/4img0224y1.jpg
http://img192.imageshack.us/img192/6438/img1815z1.jpg
^^Very nice rig :up:
What size Rad Grill will fit best on the top of the case? 120 mm x 3 or 140 x3?
Mr_Mustang01gt: be careful with 140x3 rads on top of case. Few of them are rather wide and need additional cuts of 5.25 bay enclosure sidewalls to fit width-wise (eg. you can check 800D hardware canucks mod with HWLabs 3x140 GTX rad). 120x3 (no mods or grill needed) or 120x4 rads are better choice for 800D imho.
I should clarify,
I am looking to see which of these would fit cleaner on the outside of the top of the case.
360 Rad Grill
http://www.performance-pcs.com/catal...ducts_id=28823
480 Rad Grill
http://www.performance-pcs.com/catal...ducts_id=28769
I wouldn't buy 360 rad grill at all, as 800D already has 3x120 mounting holes/grill pre-cut in. As for what and how looks .. tastes differ a lot from person to person. There is nothing to suggest that will fit for everybody tastes.
I just prefer to have a flush or slightly raised top vs. a recessed one.
http://www.overclock.net/gallery/dat.../IMAG00561.jpg
http://www.overclock.net/gallery/dat.../IMAG00542.jpg
Water cooling parts are being cleaned :)
COMPUTER SYSTEM:
CPU = Intel Core i7 950 D0 @ 4.2GHz, 1.329v
MOBO = EVGA X58 FTW3 E768 LGA1366
GPU = EVGA GTX 580 @ 950/4400, 1.138v
RAM = 12GB Crucial Ballistix Tracer DDR3-1600
PSU = Enermax Galaxy EVO 1250w
CASE = Corsair Obsidian 700D w/Window
LCD = ASUS VW246H 24" 1080P
OS = Windows 7 Ultimate
WATERCOOLING SYSTEM:
CPU = EK Supreme HF Plexi/Nickel
GPU = EK FC-580 GTX Plexi/Nickel
RES = EK MultiOption X2 250 Advanced
RAD = XSPC RX360 Triple 120mm
FANS = CoolerMaster SickleFlow Silent 2000rpm RED
PUMP = Swiftech MCP35X 12v PWM Controlled
FITTINGS = Bitspower Compression Chrome
TUBING = PrimoChill PrimoFlex PRO LRT 1/2"-3/4" Clear
Before, The Plan, The Parts and After WC:
http://i409.photobucket.com/albums/p...1/IMG_2411.jpg
http://i409.photobucket.com/albums/p...ingConfig1.jpg
http://i409.photobucket.com/albums/p...1/IMAG0007.jpg
http://i409.photobucket.com/albums/p...g/IMG_2515.jpg
afterhttp://i409.photobucket.com/albums/p...g/IMG_2528.jpg
http://i409.photobucket.com/albums/p...1/IMG_2557.jpg
And here is a link to a YouTube video of the PC booting up:
http://www.youtube.com/watch?v=cdjQNd4k_R4&hd=1
http://www.youtube.com/watch?v=VQxvfsxdVUc&hd=1
Some fantastic curves here, loving it! Well done! :up:
Thanks, I wanted it to look sexy and what better than curves :)
@Hugo381 great routing!
