You've tested the majority of them?
No they are NOT poor overclockers, but they don't overclock by themselves. I don't think I can count more then 2-3 reviews where the vGPU was raised beyond 1.162v with ATI's OV tool. We've seen the reviews, now let's see how they'll do in HWBot rankings (overclocker average graph is what I am looking for). Once overclockers will get their hand on them and put them to work, we'll know exactly how most of them clock...
You are making the snowblower rev at 5000RPM instead of normal 4600RPM and expect the snowblower to return the same fuel consumption ??
You overclock the clock so you must at least should over-voltage the card a bit as its a high end version and not a entry or mid range.
5850 OCed with stock voltage is a good idea, but 5970 Oced on stock not so much IMO.
I agree. What I don't agree with is how ATI marketed the card to the press and their board partners. I am taking issue with some of the statements here and other places because they basically repeat ATI's marketing slides verbatim. Slides that hold claims which are on shaky ground due to the unpredictable nature of overclocking. Simple as that.
Memory, yes it overclocks well. The cores? Not so much.
..just because some people don't know how to really push these cards, doesn't mean they are bad overclockers, it simply means that some people don't know what they are doing..
when the 4870x2 came out..most all review sites i saw where under 800mhz for the cores..usually 780..30mhz over stock..but when u put the card into hands of people that know what they are doing..800mhz seems like the minimum and ive seen 830(usual) to 900(xtreme)..me personally at 850core..
so ill take review sites and overclocking with a grain of salt :)
EDIT: i do see u understand it takes more voltage to get anything nice from the cores..but its to be expected with this card since its under clocked and volted to meet the 300w tdp
Core voltage increases were needed for the x1800, x1900 and x1950 in order to overclock them. Therefore, it should be no surprise if we have to still do that now. Unless some have forgotten we had to actually do that? Some of you act like this is new or something :shakes:
a low voltage cpu also sucks at overclocking, but somehow anyone who gets one knows to first up the voltage to normal levels before OCing. why is this seeming like such a harder concept?
Yeah, I bought it along with the other 2000 people that enjoyed ATI's huge stock dump just before the launch =))Quote:
Originally Posted by cowie
And yes, you are right, they are not very good clockers out of the box, they are average clockers for the high-end segment. But that is one thing, and "they are not good clockers" period is a totally different thing. Overclocking in general is a completely different thing.
The voltage scaling and the negative temperature scaling are the ground stones of overclocking. You seem to have the feeling that every chip scales with voltage in the same way, and you keep repeating that. I don't even think I have to adress this ideea...Quote:
Originally Posted by SKYTML
Ok, let's put it in like this - for daily-use, average IT-educated buyers (which is the vast majority of them) you are right, HD 5970 is not a bright overclocker, with it's stock voltage and all that. But since this is XtremeSystems, not mildly-stock-volts-systems, and overclocking usually means something a little bit different here, try to be more specific when you adress issues like overclocking.
i dont think anyone is saying that they dont clock when volt modded.
bah duel cored cards you know what to expect anyway.
thanks monstru for reply
btw
my comment was torward eastcoasthandle
Put these puppies on water! Until then I'm reserving judgement on their clocking abilities because face it, the stock cooler isn't up to the task to master 2 R870 cores at high clocks ( using stock cooling, I could burn one up in the Vantage feature tests I assure you ) Are the EK blocks shipping yet by the way?
cowie - I know, we posted at the same time :)
chickenfeed - this is the funniest part. This is the only high-end cared where I reached the maximum voltage that is possible to adjust by software, on air, and I still have scaling :) Of course, this is not for daily use, I am talking for benching and such. Anyway, this week I'll make some time to vmod the card and put it under some LN2, to see exactly how bad it clocks.
How does one just decide to vmod the card?
Is it the same on all different models of cards or just easy to trace out what you need to do by looking at the board?
Depends on the card.
if the tech documents are available for the VREGs then its pretty easy. If not then you get out the probes..
Bingo.
The card was marketed as having a large amount of overclocking potential AT STOCK VOLTS. However, it does not overclock well at STOCK VOLTAGE. Is this so hard to understand? No one is saying that with additional voltage input, the clock speeds will still be bogged down.
If anyone recorded ATI's presentation, fast forward to ~minute 40 and listen. I can't remember which slide they were presenting at the time.
