Daily point production will depend on how much your CPU is overclocked. You would likely average 5,000-10,000 WCG points per day.
I am outrageously new to this, as you can tell, and I am only familiar with the names of the clients, not what they accrue points for haha.
Thank you. I will go with Windows (64-bit of course). It wasn't a question of points just which was easier to configure in the shortest amount of time.
Hi guys, today i started crunching in this old pc i have, but i am having trouble getting both processors to work at 100%..
http://www.freeimagehosting.net/uplo...c1d4a6e7db.png
It is an athlonx2@3.2. As you can see i have already configured it in wcg to use 100% of cpu time.. any idea of what could it be? W7 32bit, 2g ram
Got it to work at full load now. At first it was only working on 1 project, now there are 2 projects and the cpu is fully loaded.
See you later
Well, joined up with WCG and XtremeSystems on WCG. Running a Q6600 OCed to 3.06GHz at the moment. Just started my first batch about 12 minutes ago.
i think that the best configure with multisocket pcs is 13 threads on a 16 thread pc is faster.
during some investigate on my rig one work uses 1,15-1,20 threads. any ideas?
Use these settings:
http://www.xtremesystems.org/forums/...3&d=1272495172
This gives maximum output.
Benchmark results
Number of CPUs :16
2291 floating point MIPS (Whetstone) per CPU
5725 integer MIPS (Dhrystone) per CPU
any comments? :S are those good numbers?
dual xeons E5520
stock speed 2,28Ghz turbo mode 2,4Ghz
Windows ultimate 64bit
those are my results from the CPU benchmark from BOINC manager
Your dhrystone seems a little low. Are you running the 32bit or 64bit BOINC client?
how can i see them and if i change my client do i lose my requests?
x86 client i cant find the x64 version
Download direct from http://boinc.berkeley.edu/download_all.php
the priority in task manager is low... for the task for evey task that BOINC has do i have to change it to normal??
That priority is normal for the default install, I leave mine running at low. They run fine that way, and only drop off when your doing something else that needs the cycles.
Rick
Joined up and doing the deed now. Lets crash ol' Big Blue Brother!
Should I do anything about errors on a WU? I feel like I'm missing out :c and like I wasted a bunch of time
ni356_ 00047_ 12-- Greyteam Error 5/2/10 06:42:40 5/2/10 11:20:29 0.01 0.3 / 0.0
Hey Folks, I decided to pitch in some cycles for the week. I have a question though...
I let in run yesterday untill all projects were finished and saying "Waiting to Report". The machine sat like that for almost 3 hours.
My pump has been making some noise so I was a little leary of leaving it run ovenight so I shut the machine down. When I fired it up this morning it started with all new data packets... :shrug:
Am I missing something? I thought it would automatically upload data to the server.... Hope I didn't lose all that work from yesterday.... :(
Joined the team yesterday. After being a passive reader here for a long time it's time to get more involved. :)
For now "only" my Xeon 3060 @3GHz is crushing but I plan to add my Phenoms too.
