All good now
http://img524.imageshack.us/img524/4...erestbeta1.png
Please a question...What is the best to overclocking?...the 759 or 760?
I used a 759 and reach good performance
http://i44.tinypic.com/106njmr.jpg
But there are no way to be a good performance without at least PCI ex on 112
Are the 760 identical?...do i have to set 110 or more in PCI ex to get higger thar BCLK 235?
if somebody can help me with this question, cause my 759 dead...and my 760 comes so soon.
thanks and sorry the broken english
I owned both, I say 760 is still a crazy clocker. it can bench @244bclkX17 on air, 3D06 passed. ;)
http://img40.imageshack.us/img40/759...clkx173d06.jpg
yep, you also need 110~112 to achieve high bclk.
+1 on 760 though I'm still learning the board
http://img.techpowerup.org/090622/5258GHz.jpg
Omg!!!
thanks for their suport friends...i will try with my new 760....i hope it get higher :)
what kind of VTT are most using with the classified. Can some one confirm that +250 to +400 it is in fact ok and not overvolting it. I thought that we should not use more than 1.45v on the vtt. What is the starting value on this MB ?
in e-leet with +250 reads 1.58v.
I believe starting point is 1.2v. It also seems like E-leet monitoring shows higher than actual? Have to get out the volt meter and check. lol
edit, just checked with volt meter. Bios VTT=1.425 measured with volt meter = 1.425v E-leet 1.58v
[QUOTE=bluehaze;3864802]The voltages in eleet are really screwy dimm voltage and QPI are way off, best to check with a dmm and if your using Elpida Hypers keep a close eye on dimm voltage have seen in another thread alot of dead hypers and i've gone through 2 sets myself.[/QUOTE
testing my new W3520.Went to 4.3 ht on 20 run linx with 1.31vcore and +150 vtt. what is your VTT setting ?
Haven't tried 4.5 HT yet got caught up trying to break 3dmark vantage 30k single card! Sooo close but can't do it! http://service.futuremark.com/compare?3dmv=1173268 need to find some tweaks for vantage.
Anyways usually only +50vtt just to be safe for 4.2-4.5 i think it would run with +0 vtt though. Only time I know I have to raise vtt is for 4.6 have to raise vtt to compensate for the bclk to +125.
Does this board support crossfireX, or should I say I have a 4870x2 that I would be using on the board when I get it. I might go to a gtx 295 or the new 5870x2, although I am wondering if the ATI cards will work with this board, I am not finding much info on this topic online. Anyone running ATI cards on the classified please speak up.
[QUOTE=Jakethesnake011;3870264]Does this board support crossfireX, or should I say I have a 4870x2 that I would be using on the board when I get it. I might go to a gtx 295 or the new 5870x2, although I am wondering if the ATI cards will work with this board, I am not finding much info on this topic online. Anyone running ATI cards on the classified please speak up.[/QUOT
The ATI cards are supported.
Of course it does support crossfire if you go to futuremark ORB to search....;)
Here is my setup:
http://img205.imageshack.us/img205/2253/setupm.jpg
http://img209.imageshack.us/img209/3...838default.jpg
Thanks I wanted to make sure before I bought one.
Diference in readings for my classified 760
http://img359.imageshack.us/img359/9...reswithdmm.jpg
Hi, I got my EVGA Classified and I have a problem with it :-( When i turn it ON, on POST-LED display lights "FF" and MoBo do nothing. CPU,RAM, VGA, PSU is OK -> tested on a different MB. I Tried CMOS reset in fron and in back, put out the battery. I realy donīt know, what to do. Please hepl me...
hlonipha
you have 2 GTX 295 Evga on your 760 ? : confused:
I thought he should have a Evga 759 ..
you are in Sli ? not in Quad ?
there is there a big difference?
EVGA Classified 760 S60V
W352O 21X211 HT Enable @ 1.42V 3850A823
CORSAIR DOMINATORS GT @ 7-8-7-20 1T
PCP&C SILENCERŪ 910
2x EVGA GTX 295 SLI
X-Fi Fatal1ty Titanium PCI-E
1 x WD VELOCIRAPTOR 300
Seagate 1TB
CM HAF 932
HK 3.0/MCP655/FESER X360/Microres V2
Windows 7 64bit
Dell 3008WFP 30"
I have 2 GTX 295 in Quad SLI. I have a 760. Here is a link for the EVGA 760 specs http://www.evga.com/products/moreInf...ly=Motherboard Family
lol you are confused cause I did not list list the word Quad on my sig????? cmon man
i dont like the new bios incase any of you guys are wondering...
infact i think i still love the original bios that came with my 759.
