Aquaero bought and paid for, and on its way over to me :) Updates soon guys!
as always, looking incredibly forward to it :)
Good Luck with the Aquaero, Nat. They are still hard to come by in the US.
So to update you all, I'm using new fittings and tubing in the new and improved resurrection of Pegasus :) Changing to 3/8" 5/8" comps in true silver and Primochill LRT tubing to try to neaten up those loops a bit more. Yes, I AM that much of a perfectionist :) And I have another idea to try to neaten the loops still further by changing the orientation of the 240 rad in the bay area, but I am not sure if that will work very well... I'll have to see when I have everything together again if I can actually do it the other way around and not have it look really weird. Plus it might end up lengthening the actual loop so much as to not make it worth my while anyway. But we'll see :) Hopefully the mount for the Aquaero will be finished and sent to me soon so I can also have that mounted in the case neatly. Apart from that everything is just taking time. But let's face it, I've been building this computer since the beginning of the year, waiting another few weeks won't hurt me. I am actually surprising myself with my patience though, it's a good life lesson. Hope to show you guys some interesting stuff soon anyways, will check back in shortly! :)
Hi, dreamaxx. I liked the work that you did before and am looking forward to your update. Being a "perfectionist" isn't such a bad thing.. I know that I definitely appreciate those who go the extra mile to keep their builds refined and neat. :)
Funny. Looked at the first pictures and I was thinking "I really like the build, nice colors, but its kinda girlish, kinda hard core something something". And as it turns out, IT IS GIRLISH ; )) Well, I dont mind, I like girlsih so...Very nice build so far. Looking forward to the new tubing n stuff! I use to have an Aquaero but I wasen't to happy with it, dont really trust the sensors I guess. Lets just hope it works bether then the other stuff you had!
This is the first time I've seen your Pegasus build. A ton of attention to detail, a big :up:
We are impatiently waiting for updates and a lot of pictures :)
Hey guys, Pegasus is going to be back with new hardware soon.
Just need to find a powdercoating place here on the Gold Coast (or Brisbane)
:D Pics soon of new stuff.
Anybody know any reasonably good fans which are either all clear or all white or silver or simple enough to make white?
Also, anybody know where I can find an Aqua-computer temp sensor and flow sensor? :)
Some good White fans ?
The nexus, fractal and gelid fans seems to be what you need ;)
links?
Maybe use Koolance's flow meter INS-FM17 with simple mod? http://www.realredraider.com/vbullet...ead.php?t=8581
http://www.pccasegear.com/index.php?...ducts_id=12439
Anybody got any experience with those?
These ?
These fans are really silents, but they don't have a best static pressure (enough for A RX i think, but a TFC, I don't know).
What do you mean in stock masska?
Anybody tried these?
http://www.performance-pcs.com/catal...ducts_id=21847
Those enermax fans look awesome, anybody got any results from them? How are they?
Sorry Nat I should've explained. I meant I have them in stock and my site www.thekoolroom.com will go live in a week or two, so if you like come on by or shoot me a pm.
I... PMed you masska.
Welcome back, Nat :toast: Looking forward to seeing Rev 2 of Pegasus.
So I need some advice on how to set up my dual loops.
I have a 240 and a 360 rad.
The following blocks:
HK 3.0 - CPU
EK - Mosfets (x2)
Koolance - NB/SB/QPI
EK - Graphics (x2)
Barus - RAM
What do you think I should put in what loop?
I was thinking CPU/Mosfets/Ram in one loop with 360 rad and GPUs, NB/SB/QPI in the other 240 loop.
check your pm's :)
Have followed this worklog from the start. Loved your front and top panels and the colour scheme you had too, especially your purple coolant.
Unusual colour but goes so well with your build. Nice to see it's back up and running and looking forward to seeing some pics. :up:
Nobody got any advice on how I should set up my loops?
