5000 vs 4900. So disappointed, if you asked me :(
Hmmm.. this contradicts my tests.
Have done several benches with 3DM06 with same MB/CPU (Q6600/Q9450) swithcing from 9600GT, 8800GT, 2xHD3870 and now HD3850x2.
The CPU score stays consistent - OS=WinXP 32-bits.
If you get 300 more pts as stated above by disabling services, then I would call that a "normal" user install (lotsa crap starting up) and not a "bencher" install.
Are you sure this is with the same OS? (Preferably a tweaked "bench-OSDisk" the same for all systems).
OK. Enough off-topic from me, and I could be wrong of course. It has happened before. :)
No one postet it yet I think.
Quad Core Round Up: AMD Vs Intel Clock to Clock
Respect for the hardwork.
Few questions. Do you have a power consumption deneb vs. agena and what voltage did you need for the deneb oc.? Turbo on on i7 I assume?
This review is a little bit confused IMHO. And what's this?
http://img145.imageshack.us/img145/4...eekgeekdj7.jpg
:eek: :ROTF: :rolleyes:
I'm still waiting for a straight review with the following CPUs:
Phenom 940 (3.0GHz)
Phenom 9950 (OCed to 3.0GHz)
Core 2 Extreme QX6850 (3GHz)
Core 2 Quad Q9650 (3GHz)
Core i7 940 (OCed to 3.0GHz)
Charts explanation:
Agena = Phenom I
Deneb = Phenom II
Both processors clocked at 3GHz and compared with each other to show the differences between these two.
Deneb = Phenom II
Kentsfield = Core 2 Quad ( 65nm ) [ Q6600 ]
Yorkfield = Core 2 Quad 9 ( 45nm ) [ Q9450 ]
Bloomfield = Core i7
All of them clocked at 3.7GHz for a clock per clock comparison.
I'm having trouble finding what's wrong with this comparison to you.
I think the most interesting part of the clock2clock review is the power consumption.
AMD looks pretty bad there... :shrug:
I think both processors NB clocks were equal in the tests, but I'll have to check it out again to be sure.
It's absolutely possible though.
Being a new and supposedly faster ( and truly faster in most apps ) processor doesn't make it unbeatable, and of course doesn't mean that the older "revision" can't surpass it in a few tests.
p.s. I doubt that the NB clock would make any difference in the FPU tests, can't guarantee that, but I'm pretty sure ;)
Nice work! And very good conclusion.
well only a few more days till more data should be available and then we see whats up with that.
Oh and that winrar score seems a bit low compared to what we'd expect from Phenom II.But a few more days and we'll see what's up with those numbers :).
Er, didn't your Agena beat Coolice's Deneb in Wprime?
http://www.ocxtreme.org/forumenus/sh...03&postcount=8
And the Deneb score for 32-bit Cinebench 10 looks right, it's just the Agena score that seems higher than expected.
As for wprime and Agena beating Deneb,the culprit is the OS used.Justapost already spoke about this IIRC.
Cinebech score for Agena is a bit high in hwbox review while the Deneb one is a bit low,so this could be the reason fo so close scores.I remember the 7-9% better scores per clock from the initial tests with C1 Denebs.
