if i had change log it would be published in english. :) ex-gf is hungarian?
I updated the Front page with the bios from the hungarien link. I will personally try it to confirm it works ok. i will post back with results.
Up to 226 bclk Dram @ 1.64 , QPI @ 1.41 here is Vantage run @ 226. Only other voltage I changed with was the CPU amplitude setting which is at 700v. Asus TurboV software gave out at 226 bclk:) CPU-Z
Any word on the new bios?
Yeah, what does this bios fix??
Coud someone with coldboot/ram issues try this on their other bios chip? Would like to know if those dumb asus techs have accidentally fixed something. :/
EDIT: Guys i may have found something! Try disabling Quick Boot from BIOS before you test that beta version and see if the coldboot problem still exists.
I'm on the new bios. No news on whats new. I've looked through the Asus forums and have'nt found anything on it. I'm not experiencing the cold boot but so i'm not for sure if it fixed it or not. I am now flashing back to 0704 as that's my fav bios so far. When Asus makes this one official or puts up a change log I will post it. But until then i'm flashing back. I just wanted to confirm that the bios was ok to use. Which it is. No new features that i notice. Probably some memory compatibility fix's.
What? So disabling quick boot eliminated the cold boot problem? Or are you just mistyping something...
So I know this is all a bit preliminary but I installed this 0901 BIOS and while I see no visible changes I noticed that my temps in real temp dropped significantly (about 5C-10C) compared to before and as I am typing this I am running a 100% load stress test on 4 cores/8 threads at 4.0GHz with 20x200MHz. All settings Auto except for memory profile X.M.P. Temps are maxing out at 76C on cores 1 and 2, 75C on cores 3 and 4. 12 minutes in right now...
:shocked:
Scratch everything I said. No difference going from 0804 to 0901. It was a fluke run.
http://www3.mediafire.com/imgbnc.php...986cf66a5g.jpg
Seems like a slow super pi, does it not
so is the 0901 BETA worth a try?
