because UD5 will not be able to do vdroop through bios with current board revision
it will need to be revised as far as i know
Changing mobo then! Droop, slow post, and no chassis fan controler are things in wich P6T takes advantage.
Guys what bios for the Extreme can you recommend? F3 is fine but for issues with 8x mem divider at higher BCLKs.. mobo won't post -.-
these everest memory benchmark scores are great.this might sound dumb but i have a quick question guys,with read/write/copy in the 20k range and latencyin the mid to high 20's,can you actually feel the difference between this and 775 ddr2 boards in everyday use?cause just going by the numbers should be about twice as good.just wondering if it really translates in real world use? thanks
i had a e8500 @ 4.12 with 2 gig 1066 mem
change to 920 @ 4.2 200 x 21 and 3 gig 1600 mem
the system responses quicker and seem smoother overall
wether its worth the extra £
i think it is
the only problem i have is the lack of a mounting plate for any fuzion v1
I knew it was going to get hot but 83c...wow I would have freaked LOL. That is why I didn't even run prime or my favorite OCCT. I played Warhead (the train level, forgot what it is called) and it was very smooth at 4.2GHz. I am comparing this to my e8600@4.5GHz which also did well.
Rev what were your NB temps? Thanks again for posting your settings.:up:
Started a Living Review here.
http://www.images.clunk.org.uk/revie...p-angle-sm.jpg
Added a full set of voltage measuring points here too for anyone that's interested :)
23k passed :D:D
http://photodorp.com/out.php/i515_screen016.jpg
Well the Extreme does droop as well.. kinda hard getting used to when you're coming from a 0,0-droop-no-matter-what mobo (my DFI).
I had both the extreme and UD5, no difference that i saw besides the cooling, i put both boards side by side and looked at every component used, looked identical.
Mine maxed out ~54C with that huge extra heatsink attached and waterblock attached but no water going through.
Removed the big thing, removed the water block, put a tricool spotfan (quiet fan) directly on NB and now temps max out at 47C.
That big thing on mine only made 1-2C difference with on vs off, even with fan hitting going through it.
My X38T-DQ6 almost caused me not to buy the EX58-UD5. First Rev. Gigabyte boards left a bad taste in my mouth ;). Unfortunately a minor accident with a loose hose clamp resulted in my X38T letting out the magic smoke :explode2: and I suddenly find myself looking for a new mobo, and while I'm at it I'll just upgrade to i7.
This board is the only one that puts the useless (to me) PCI slots right below the pciex16 slots so I can run my CF cards and still put both my raid cards in the pcie slots they need. BTW, this thread, and Dinos' testing thread are what convinced me to pull the trigger. Kit will arrive tomorrow.
Regrettably I'll have to use air cooling since the Mrs. demanded I not have a repeat of an accident with the water. If anyone is interested I'll be using my old 1.8v 1600 7-7-7-20 ram, so I'll throw some feedback on whether or not I toast my new 940 with it.
Peace
