210/3=70mhz agp. that can't be what's holding you back then. it must be something else.
your max fsb without an agp lock will be 73*3=219fsb. i suggest an nforce3 chipset with a locked agp bus if you want to go over 220fsb
any1 wan buy a K8V-max3? :D
hehe
well imma give the board a try first... if a no go... ne1 recommend a good NF3 boad dat'll allow me to hit 300mhz FSB or more? (of course wit multiplier drop)
[edit]
i decided on cancellin' my order on the 3200+ n got the 3400+ a64.
thats comin' friday along wit the abit k8v-max3
so i'm guessin' i'll b receivin' 2.4ghz clock @ 219 but than again i dont kn0 what the 9800XTs agp clock kill...
i'm goin' retail on the radeon9800XT and gon vmod that sucker (P.S. where can i find the VR resister @?)
spendin' over 1500 on this system (sheesh!!!)
at least 90% of the parts i can use again such as mem, case, psu, etc
OPP, do you have GB K8N non-pro ?
I need some voltmodds to my K8N non pro i think.. my cpu is at the post office in few days :banana:
I have the pro version myself, the mods may be the same. Macci has a non pro he could tell you the mods.Quote:
OPP
I heared that a to high Vddr can damage the onboard memory controller from the CPU. Is that true?Quote:
OPP
Is 3.61v (3.3v rail) dangerous? I don't wanna fry it :)
here is my a64 3400+ chip
ADA3400AEP5AP
CAA0C 0348XPMW
9778034L30579
i'm decidin' on whether to get the gigabyte k8n-pro or the shuttle
AN50R?
P.S. any1 know bout that stepping... good OCer?
Its up in the air at the moment, kakaroto.
A64 3200+
ADA3200AEP5AP
CAAMC 0339WPMW
9446635J30492
1.700V, 250*10, watercooled
I got a BROWN 3400 + it does max 2420 on air with 1.65 vcore
ok i'm hearing brown and green...Quote:
whats the difference and how can you tell?
MickeyM is your 3400 brown aswell?
how high did you manage to clock it on air? also tell me with what multi and fsb :)
Is 19200 3DMark2001SE Points good @ 2Ghz ??
Btw., what is the diffrence of 2.5 and 3 LDT ?? And will i get higher score if I change to 3 insted of 2.5 ??
And finally: How the hell do I chance my CAS latency ?? (i have a Chaintech mobo).
Thx dudes :)
No one has the 9-18 bios anymore? :(
I've been looking all over for it.
MM I have a Radeon 9800Pro :)
2x 512Mb DDR PC3500 Mushkin Level II Hi Perf 2-2-2)
433Mhz, 184 pins, 64 bit, CL2, rated 2-2-2
Dual channel optimised, w/ alu heatspreader
€388
Hov does that sounds ??
Got me a 3400 chip.
Runs 3D at 3000Mhz with memory running at 250 agressive timeings. This is with 404A MachI. Nice Chip. Stock Radeon clocks get me around 24100 marks, 400-500 behind FX-51. Seems to Overclock about the same as my FX.
OPP
Very nice 'single phase' clocking :D
Now it just needs some 270+ RAM loving and we are looking at new top numbers eh? ;)
Now why aren't the 3400 chips available up here yet ?? :/
I want one :D
270 ram would nice :D
I swear this Kingston of mine has never giveing me any better then 255,,pushing it!!
Then again macci might be able to do something with it:)
OPP
Orak,
Here is some stuff on GigaByte K8N Vdimm/Vbt mods. Vcore mod is the same as on K8NNXP/Pro
OPP, what board are you using with the 3400 now? Shuttle?
OPP what colour is your 3400 + ? Brown or green
My new 3200+
http://www.yamafoto.com/users/niaboc...0_0344SPMW.JPG
I can do 300*8.5 with 1.78v and watercooling but i only test it One hour!
tnx mate:)Quote:
Originally posted by macci
Orak,
very nice overclock ther OPP:toast:Quote:
Got me a 3400 chip.
OPP
was waiting for you or macci to get a 3400+, i see your running 2.0vcore... the most ive tried is 1.95v with my custom r404 chiller by herefishy... at stock volts according to the bios it reads the cpu temp at about -21C, with 1.95v it reads about -8C which is why i have been hesitant to run 2.0v.. Just curious what your cpu temps are with your r404 chiller with those volts?????
wow -18C load is 10C colder than mine, nice.. hmm i havent read about the OVP being 1.94v, i will have to try 2.0v i guess just too see...Quote:
Originally posted by MickeyMouse
at 276x10.5=2.9ghz@1.93v I saw -18c load with dryice/acetone :)
CCC I heard there was an OVP at 1.94v+ on the shuttle so I neevr tried higher either.
