Originally Posted by Kris View Post
Ran into some trouble.
I think I may have cooked the ram playing with some of C-N's voltage settings.
Update- Ram died! Old set passed. Oh well at least I had a spare set....
Sorry for your loss, The RAM is rated at 2.3v so it should have been alright but personally I would always use active cooling & I would have throttled the vdimm back as far as I could once I got the rig stable before pounding it with Prime95.
Now you've learnt the hard way, you wont do that again will you
I actually kept it @ 2.1 to 2.27. I think the ram might have been bad from the get go as I had so many issues when I first built the rig. To be honest I abused the crap out of my first set and they are still running strong.... As for active cooling I have a 150cfm delta pulling across the ram and enough 90 cfm fans in the case fans to blow the curtains in the window behind the case up the wall.:p:
