My problem is the VTT, all under 1.55 - 1.6V > not stable !
i sure hope you don't really mean vtt there.
cos vtt that high is guaranteed to kill your chip and fast.
i've only gone up to 1.52 for quick math benching at 8x540.
What Ram could you guys recommend me to use on this board?
This good ram for it:
G.Skill 4GB (2x2048MB) DDR2 PC2 8800 CL5 4 GB, PC8800, 1111 MHz
Or do you have other suggestions? (i want 4GB)
Hehe
My QX9650 like the UD3P too :)
http://img147.imageshack.us/img147/1...0cpuvalpe5.jpg
sweet! post the ET6 for that clock?
do you need voltages anywhere near my 1.7pll, 1.5vtt, 1.47vcore, and 1.8vnb?
Yea, love to see the setting s for that run.
I have tried all these different settings and suggestions but still no go past 425, that is weak. It looks like I got a bunk board. I have an RMA number already but I cannot ship out until I get paid in like a week. I am hoping dor a primo cream of the crop board next time, well aren't we all.
Hey did any quad user succesfully using S3 mode with this board at 400 fsb and above ?:confused:
I mean no constant reboot in in infinite loop with a blank screen when wake the system up.
More isnt possible :
http://www.abload.de/thumb/settings2ci5p.jpg
What a bad board :/
In 2 - 3 days i have a new GA-EP45-UD3R ... lets see .....
From know on I love this Board!
All results on AIR!!!
1M
http://www.abload.de/thumb/1m25ke.jpg
32M
http://www.abload.de/thumb/32mf265.jpg
Vantage
http://service.futuremark.com/compare?3dmv=507443
Mark06
http://service.futuremark.com/compare?3dm06=8804750
Prime with 4250 on AIR!!!
Q9550 | 4250MHz | 1.408v | FSB500 | DDR2-500MHz | Gigabyte UD3P | LuKü | L835A730 | T | 1,25v | emertX
http://www.abload.de/thumb/unbenannt4jp10.jpg
lol nice
i dont get the board
i did some testi last night again and no matter what i try i cant get any decent FSB to stick
leaving on auto voltages allows me to boot at 620 even but as soon as it gets a whiff of the HDD it bombs out or corrupts my bootmngr
i have tried practically all combinations of skews i could think of and nothing is working...that is the only other thing that i can thing of not helping
i've played with reference VTT as well but no go
just not having luck
swapped boards to EP45 EXTREME and on first go
http://img412.imageshack.us/img412/5...pionairmf6.png
:shrug:
could it be the bios i am on........i'm on the F4Pi bios (bios is called F4-4 bios as well..)
has anyone else noticed that VTT Reference volts dont seem to change in Easy Tune6
Could that be the issue
Test the F5
Hey guys
Got myself a ud3r yesterday, but only managed a 600mhz 1m. Any tips wrt the clock skews? 550 isn't even 32m stable :(
Also, F4 bios was AWFUL so I switched back to F3.
Mike
http://valid.x86-secret.com/show_oc.php?id=443671
http://www.abload.de/img/459ghztrd103k60.jpg
if anyone needs settings you find lots of mine at the ud3p thread in the intel hardware section.
It's a crazy board for the memory frequency .
I can't post actually because there's a contest.
For the quad it's the best if you've got good memory .
First play with this board
BIOS - F4
Crucial Ballistix Tracer - 2.4V
CPU & NB H2O cooled
wPrime v1.55
http://img.photobucket.com/albums/v3..._545fsb_wp.jpg
Everest scaling w/PL level - How low can we go? :p
PL 11
http://img.photobucket.com/albums/v3...erest_pl11.jpg
PL10
http://img.photobucket.com/albums/v3...verest_pl1.jpg
PL9
http://img.photobucket.com/albums/v3...verest_pl9.jpg
PL8
http://img.photobucket.com/albums/v3...verest_pl8.jpg
I love this board!!!
Hey Guys, have a look at this!!!
On Air-Cooling! IFX-14!!!
Q9550 | 4352MHz | 1.456V | FSB-512MHz | DDR2-512MHz | Gigabyte UD3P | Air-Cooling | L835A730 | T | 1,25v | emertX
http://www.abload.de/thumb/unbenannt4350_2hya2.jpg
what is the best memory do you recommend for using the Q9550 ? I was thinking of the Dominator/ Tracers/ Ballistics [cheapest] or GSkill [which seems most compatible] or OCZ Reapers?.
get tracers dominators or ballistix, no need to pay extra
....(((these are my latest 24/7 setings for 4455mhz ran prime blend for hour,s with no errors while watching movies on you tube and downloading music on lime wire))).....
GIGABYTE EP45-UD3R..INTEL E8400 E0 BATCH#Q829A103..CELLSHOCK D9GKX
ROBUST GRAFIX BOOST............TURBO
CPU CLOCK RATIO...................9X
CPU HOST FREQUENCY.............495
PERFORMNCE ENHANCE.............EXTREME
MCH FREQUENCY LATCH............333MHZ
SYSTEM MEM MULTI.................2.00B
NEXT YOUR RAM SETTINGS MINE RUN 4-4-4-10...SO SET YOURS TO RUN STABLE YOU MAY NEED SOMETHING LIKE 5-5-5-12
I SET MINE TO PERFORMANCE LEVEL 9 PL8 RESULTS IN INSTANT CRASH EVEN ON 1.2400 VCORE...I USED MEMSET TO LOWER A BUNCH OF MY SUB TIMINGS MOST OF IT CAN BE DONE IN THE BIOS BUT I LIKE IT CUZ I DONT HAVE TO KEEP REBOOTING TO FIND THE TIGHTEST SETTINGS FOR MY RAM,S..
LOAD LINE LLC.........................ENABLED
CPU V-CORE...........................1.37500V...you may need more..you may need less i can bench less but 1.37500V keeps it ROCK stable
CPU TERMINATION...................1.42000V..this is as low as i can set it to be ROCK stable unless i jack the CPU PLL up to like 1.5700V or more
CPU PLL.................................1.2500V
ICH I/O..................................1.2500v..((your board may need pll and ich l/O up to 1.3500v))
DRAM.....................................FIND WHAT DRAM SETING YOUR RAM NEEDS TO RUN AT 990MHZ
(((ALL OTHER SETTINGS AND VALUES ON AUTO))) AND THIS WILL MAKE FOR A FAST 24/7 RIG....but im still shooting for more ghz.:D ive benched 520x9 and ran 1m super a 10.000 flat or it was 530x9 i ran both but cant remember which one i ran super pi on...im going to try new skews to get stable over 500 with less then crazy volts..im a 24/7 kind of guy....bios f3 f4 and f4a beta seemed the same...these settings worked on all 3 bios,s for the UD3R it should work for the ud3p also but hey i could be wrong
Try F6d here
heres something to keep this thread goinghttp://i37.tinypic.com/e5puvk.jpg
