Did you get the video ok? Asus never calls back when they say they will :(.
I found em right Here :up: from what I've seen those kits hit 1200MHz pretty easily.
truehighroller; I havent watched the vid yet, it was buffering _very_ slowly when I tried, and eventually I gave up. I'll try gain a bit later.
Bad thing is that they are only 1Gb a piece sticks. I want the 2Gb a piece sticks and at low latencies. Mine seem to do pretty darn good here at my 1152Mhz~ though so I guess I should just deal with it. Just like I want a dual core but yet I know I will have to switch to 1:1 to get the clocks every one else does and I don't want to run at PL10 so, I might just stick with this Q9450 until I upgrade to the new Architecture, once it gets cheaper ofcourse. Hell I want some good DDR3 2000 Woot.. As far as the video goes :shrug: Maybe I will download it and see if I get this issue. I have it on my PC already course, and watched it though and it seemed fine to me. Maybe you are trying to stream it? If that is the case you might want to actually download it then watch it. That server kicks arse that is for sure I was pulling 1.8Mbs from it when I tested the Linky.
2GB memory is plenty, even for Pista. (formerly known as Vista). Many people just aren't aware of services.msc ;) lets you turn a whole hoast of useless crap off or set it to manual so it don't start with Windoze. That lil trick significantly frees up your memory :up:
What services are good to turn off though. I know there are a ton that steal memory but I just never researched which ones to turn off.
I actually had 2Gbs of ballistix the two sided ones and sold them because when playing crysis my shiznit was like jerk move jerk move on day and I was like well screw it and got these sticks.
With 1402 BIOS i can do this stable :
JumperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: 8,0
FSB Strap to North Bridge: 333
FSB Frequency: 552
PCI-E Frequency: 103
DRAM Frequency: 1104
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time: 50
Write Recovery Time: 5
Read to Precharge Time: 3
2nd Information :
READ to WRITE Delay (S/D): 8
Write to Read Delay (S): 3
WRITE to READ Delay (D): 5
READ to READ Delay (S): 4
READ to READ Delay (D): 5
WRITE to WRITE Delay (S): 4
WRITE to WRITE Delay (D): 5
3rd Information :
WRITE to PRE Delay: 10
READ to PRE Delay: 5
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 5
ALL PRE to REF Delay: 5
DRAM Static Read Control: ENABLE
DRAM Read Training: ENABLE
MEM. OC Charger: ENABLE Moderate
AI Clock Twister: MANUAL
AI Transaction Booster: AUTO
Common Performance Level [10]
Pull-In of CHA PH1: ENABLE
Pull-In of CHA PH2: ENABLE
Pull-In of CHA PH3: ENABLE
Pull-In of CHA PH4: ENABLE
Pull-In of CHB PH1: ENABLE
Pull-In of CHB PH2: ENABLE
Pull-In of CHB PH3: ENABLE
Pull-In of CHB PH4: ENABLE
CPU Voltage: 1,46875
CPU GTL Voltage Reference (0/2): 0.625
CPU GTL Voltage Reference (1/3): 0.625
CPU PLL Voltage: 1,56
FSB Termination Voltage: 1,30
DRAM Voltage: 2,10
NB Voltage: 1,40
NB GTL Reference: 0.595
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: ENABLE
CPU Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
CPU Margin Management : Performance
Advance CPU Settings
CPU Ratio Setting: Manual
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
http://img385.imageshack.us/img385/4...456vlf2.th.jpg
I am happy :) With 1306 BIOS i can step over 546 and with 1201 and before maximum was on the 532 FSB... Also i tightened timings of the RAM with 1 notch down and it works fine... I hope i will go over 560 FSB soon...
Thank you sir,
I couldn't find that screenshot, must of been on a DVD I made but that got cracked somehow :\ I did find this image though :D
http://img.photobucket.com/albums/v1...pyaccident.gif
That is just as good. :rofl:
I can put more than this voltage... But temps are max 64-66C at 100% load... I use only Evercool 12cm fans 2300 RPM and had 4 of them, 2 for CPU push-pull and 2 for back of the case... Plus 92mm fan on the cover and 3x92mm for HDD's... My CPU does 4550 with same voltage and max tem around 68C 100% load...
They have duplicated my issue WOOT!! I am waiting for them to see what the issue is now they think it is driver related but I changed the drivers to be the right ones because Vista installs ICH9 drivers by default and I installed the ICH10 drivers my self and it still happens so, I told the guy that info and he is looking into it as well as his boss as this point.. I am so happy now it has been duplicated and I am not crazy any more...
...All you need do now is wait about 10 years while Asus try to figure out whats doing it :p:
I know right. :(
well i just ordered a P5Q-E from newegg.
im running a Q9550 E0, G.Skill pc8500 (1066mhz) 2x2gigs ram.
what bios would you advise me to try first?
curently im hitting 3.8gigs @ 1.285 vcore on my p35 board. so anything higher than that will do me good ^^
Start with 1201m, most seem to like that version.
1201 is good, 1306 and 1402 are all great. I like the latest, 1402.
thanks for the fast replys ^^
also what version are the R2 bios posted here?
For your P5Q-E? 1306m.
Which is reccomended bios for great OC on Q6600-65nm? 1306m or 1402m? I want > 400 FSB... with old bios (803) i give 1,46v to cpu (dual fan air cooled), but i want try to lower vcore.
My ram is Corsair Dominator 1066MHz.
Thank you for your work Ket :)
