Originally Posted by
rge
After passing all other versions, I just got 2 errors in 15 passes of version 1.5. Tried increasing vcore, FSB, MCH, but still failed, so put them back where they were.
My memory is undervolted at 2.05 (instead of 2.2), which was stable a year ago. So I increased to 2.1V, and then passed version 1.5, and double checked with 50 pass run, just to make sure I did not pass by chance.
I just think each version with different Linpack libraries has gotten more efficient at finding errors, though I cant speak for those using 64 bit version.
Just in past few months I would get a random crash/lockup for every few hours of gaming, usually at high demand times. After trying everything CPU and GPU OC wise, different video drivers, and fresh image installs, (gpu is watercooled with max 58C) just gave up. Maybe it was the memory needing more volts after 6 months of use...time will tell. Should have thought of the memory before.
