Mine is on the way :D What were your settings for FSB 615mhz? That' s a really nice E8400 you have there btw ;)
I don't have them right now but as far as I can remember might be:
vcore:1.33v
vpll: 1.55v
vnb: 1.49v
vtt: 1.35v
CPU GTL: 0.61
NB GTL. 0.58
FSB Vref: 2A
I've got a problem with DK P45 plus version with E8400 E0 . Thought I can do easily 500*8 but I Cant, though I think I put enough vCore to 1.4 and VDimm to 2.1
with beta bios 09/10.
any suggestion?
Has anyone going for high FSB experienced a hard wall? I've gone up to 563FSB without really touching anything and then I can't go any further regardless what I do. Is it common to hit such a wall then have to go crazy on the voltage to go any higher? If I go to 564FSB (or above) with the same settings, the system won't even post. Settings using a E8600:
vcore:1.43v
vpll: 1.55v
vnb: 1.40v
vtt: 1.38v
GTL: 61x 61x 58x
FSB Vref: Auto
Tried 63 and also 67. Also tried 2A/2B for the FSB Vref.
CPU voltage for 563x8.5 on air. I find it unlikely that's the issue. At least not for going up 1 Mhz.
What settings are you using for your rig? Perhaps I've missed something else.
I'm not saying I don't need more voltage in other places. I'm just shocked that I could hit such a hard wall where the system won't even post. I hope 563 isn't the limit for the CPU.
I figured it out. FSB hole between 563-570. Testing now at 575.
How far did u get bu now :D ?
Nice one housERaT, im sure youll get your 32M 600fsb.
Can someone help me to find the other smartguardian or skin ?? I dont like the one that comes with P45 because it screws up me screens. I have seen other using the "old" ones which have simular dimensions to cpuz and gpuz but cannot find them :confused: Thanks :up:
my 24/7 OC for now :
http://i14.photobucket.com/albums/a3...ld/44prime.jpg
CPU isnt so great. Needs quite a bit of vcore to stabilize.
waaaaaaa man i was doing so well on some 3d benches with my e8600 510x10(took more volts then my ut p35 thou 1.55 and 1.50 for the p35)now "88"crap
i guess i'll give it a nap for a week,the normal few hours with the batt out no help.
My Q9450 C1 result done today on a very hot humid day.
http://i173.photobucket.com/albums/w...RUE_IBT_OK.png
A Qns
what NB waterblock is able to fit this mobo ? thanks
is the bios settings here in the DK same with the JR?
thanks nidecker
:confused:FSB600 x 7.5 32m pi
http://www.coolenjoy.net/bbs/data/ov.../600.jpg_f.jpg
FSB638 x 6
http://www.coolenjoy.net/bbs/multi_p...0ad3f19._f.jpg
http://www.coolenjoy.net/bbs/multi_p...2838_0863b0a0.
http://valid.x86-secret.com/show_oc.php?id=419014
FSB640 x 6
http://www.coolenjoy.net/bbs/multi_p...2838_5c424c88.
How do I run the DFI DK P45 T2RS PLUS vmod ...?
http://www.pctunerup.com/up/results/...fc1ca62ab6.jpg
I would like to know exactly how to vmod.
(100k or 50k ohm to ground)
I do not know whether any way to vmod ...
