Its obvious that P45 is a lot of better than p35. My difference is more than 50Mhz FSB
@ Kean
my E8200 did max. 550FSB for SuperPi 1M on P35 Chipset (P5K-E & Foxconn Mars P35) and
556FSB for a validation.
On the P5Q-Deluxe did the same CPU 605FSB for SuperPi 1M and 615FSB for a validation.
what is the highest fsb for P5Q3 Deluxe so far using 0702 bios?
FSB 625.23Mhz so far , here bro - http://www.xtremesystems.org/forums/...69#post3053369
Chri$ch: can you share whit us your bios seting for 615? tnx
I have problems whith pci-e frekfency. 100 work fine, every thing higher non boot. I see in setfsb pci-e is 125(bios 100).
my result with water cooling:D
What's the best you guys are getting on Air?
Amasing Result again Venom... any chance to fill in my Template (link below) I could get the QX9650 at 500FSB, but think the 4gb killed it's stability as I needed to run 1:1... Hope to test with my Gskills HZ this weekend which run 1200Mhz too...
Link of my template :http://users.pandora.be/OAP/P5QDlx/P5Q%20Dlx.rtf
wow! and you get this fsb with Bios 0506, try with 0702 :D
Hi first post here , has anyone tried a xeon in this board yet ? I have an x3360 already and my P5Q should be here friday . I didn't see any xeon's on the supported list although they are just a Q9550 with 2 added instructions . I've been reading about this board for a while and having had nothing but bad experiences with 780i's I decided to go back to an intel chipset .
I just got my P5Q Deluxe set up last night with X3350 (same as q9450). It works very well. With only a few minutes of tweaking (thanks to the advice and bios files posted by others in this thread :up: ) I was at 480 FSB OCCT stable on air. That's already about 10 mhz higher than the max I've achieved for this chip on other boards and I know it will go higher once I get a chance to spend more time with the board. First impression is, this is a golden board for 45nm quad. :D
Think the 0702 bios will work with the vanilla P5Q? Asus's site has 0 updates. I ordered one a minute ago and will do some testing. NM pretty sure they wont :(
Sweet thanks , I can't wait to run my chip on this board . I had it running @456x8.5 24/7 and my latest 780i failed after 5 days making a high pitched squeal and then a sizzling sound lol what a pos ! The cpu seems ok still , the board did boot again at stock settings but it was really unstable .
@Venom-Crusher: Would be great if you tell us your voltages. I've a yorkie right here too but i cant get em over 480.
Nobody can test a over with diferent 1:1 fsb/ram??
high fsb and diferent 1:1, with more frequency of memory than cpu
thanks
Do the MOSFETS on these boards get really hot? I was thinking of getting the PRO model, but it doesn't have any sinks on the FETs.
'fet sinks usually do more harm than good due to poor application and board warping due to poor heatsink installation methods.
NCIX finally got these in stock.
I ordered one (the P5Q Deluxe).
It should arrive right before or around GTX 280/260 launch. :D
here in brazil, the p45 not avaiable yet :(
and when it will avaiable, it will much expensive...
I will have to wait some days for buying :down:
