Up-date the 3850s have made it into the 17,000 point land it nock 17,131 score using 8.9 drivers, 4 3850 @710/874 , cpu 3.225 ghz. dohttp://service.futuremark.com/resultAnalyzer.action?resultId=8293054&resultType= 14wn
Crap how do you post the link in so it works ??
You need to log in, make the result public in your ORB account and copy the Comapre URL it gives you, then in XS Message click on the link icon at the top of the window and paste the compare url in the window that opens....
nice score by the way, looking forward to seeing the compare url...
Thank you Kazgirl i try it again http://service.futuremark.com/result...&resultType=14 my rig hit a CPU bottelneck last night try using some video cards over clock that have work good for me in the past and the rig slow down i think the Phenom just can not driver the rig any faster why been clock at 3.2ghz in my bench testing setting. I did hit 113 FPS score in Canyon flight test (test of crossfire) so crossfire running darn good . Again thank you for the help Kazgirl i'am a old fart and not that good with this intertnet stuff like you young people are but i'am trying.
A little bump for ma self,before I fall out from the table:eek:
SocketMan SLI-8800gt 700/1750/1000 - Amd Opteron165 3133Mhz 12551
:rocker: Socket939 F.T.W.:rocker:
Update:
Sig Rig @ 3.3GHz and 3x CrossfireX @ 827/1267
17,958 - http://service.futuremark.com/compare?3dm06=8329010
So Stinkin Close to 18,000
Grats on the new score and mother board Ben Brown
Well i took my best shot at Ben brown but my rig has hit a wall at 17,131 for the first time my rig slow down when i started to over clock my video cards faster. I never seen that before on my rig . Not sure if the 750w PS is running out of power to drive the 4 video cards when overclock and the cards see the system short on power pull them self back or it could be with my CPU only able to hit a max over clock of 3.2 ghz there not enought CPU power to drive the 4 video cards faster . You guys got any ideas ???
I am almost 3000pts behind now....:eek:.. I guess I need to do something...I keep falling lower on the chart
My first guess would be the power supply. Do you have any case fans or extra drives that you can unplug to see if the extra juice makes a difference. I think that is the reason I am having trouble getting too much higher of an overclock on my machine is because of not enough juice and I only have three.
Well, my PSU is about to croke..It is smelling somthing nasty..But, I was able to finally run both cards and a good OC and here it is... Let me volt mod the other card and get it above stock.. And i My friend will have the record MuWahahahaha:yepp:
9950 @ 3.3ghz
2x HD 4850 X-Fire 1: 800mhz core/1050mhz mem, 2: 625mhz core/993mhz mem
H20 Apogee
Compare Link
http://3800z24.info/Phenom/9950/32bi..._HD4850_x2.JPG
Well Im back just hooked up the H20.... Temps are looking good.. running 3.5 doing a movie recode... 1place here I come..lol
http://img72.imageshack.us/img72/9109/tempswaterxf3.jpg
http://img72.imageshack.us/img72/tem...pg/1/w1143.png
Looky here
18,000
Grats guys on all the great score . Ben Brown i been thinking about what happen on my 3dmark-06 run and i think your right power supply is starting to run short on power . I'am going to open up the case set up a fan to blow on the mother board pull off 3 of the case fans try a run see what happens . I give this a try when i get home from work tomarow .
Hi guys :)
3DMark Score = 18015 3DMarks
SM 2.0 Score = 6760 Marks
SM 3.0 Score = 8810 Marks
CPU Score = 5070 Marks
OS = Windows XP x86
CPU = Phenom 9950BE
BOARD = ASUS CROSSHAIR II Formula, BIOS 0701
GPU = ASUS 9800GT Ultimate
Drivers = 178.13
http://service.futuremark.com/compare?3dm06=8356886
http://img20.imageshack.us/img20/567...50beasunt3.jpg
:up:
Wow congrats BEN ,,GEO nice breakin the 18's
I started Ocing my little 9800GTX+
TA770//SB600
9950 @3.45mhz
Single (stockcooling)
9800GTX+ 830//2000//2400
Driver 178.13 Xp32bit SP3
http://i168.photobucket.com/albums/u...erra/16161.jpg
You must have sold your soul to the devil (I am looking at the 6660
in SM2 test :rofl:) very nice 18.000:up::shocked::clap:
aGeoM
Does it for the Green Team !!!
What the f$#k is going on:shocked::clap::up: are you two markfixing?:rofl:
Both NV and ATI go 18000 !
Time for an update MSIMAX;)
I just wonder if, I was able to set a 3-Way SLI ... I got 4 of those 128 shaders 9800GT's ( Re branded 8800GTS I guess...) to test, all clock around 800 GPU/ 2000 Shaders/ 1100 Memory, without Vmod's.
ATI's are the way to go, but can't CF them on nvidia chipset :( , something that AMD/nVidia should work together to enable both CF/SLI in the chipsets, similarly to I***l X58 Chipset.
No, vCPU in BIOS is 1.58~1.60v.
Very good score, man.:up:
My best single 9800GT score was around 15k.
Just to full fill MSIMAX will. :rofl:Quote:
Originally Posted by SocketMan
Thanks man...your's too.:up:Quote:
Originally Posted by Ben_Brown
:toast:
Imagine if someone ran 4x 4870X2's in CFX with a 3.2GHz to 3.6GHz AMD Quad :eek:.
