Originally Posted by
jcool
Hey milkmandan,
I agree with jaco, get the Z7S WS. It is far more suited for your task when compared to Skulltrail. I dare say it in here, the Z7S is also more mature than the Skulltrail, since I keep reading about people having ram/vga card/whatnot issues with Skulltrail.
Also very suited for a "beginner" like Jaco said, can't do much wrong as long as you update to current bios first :D
Anyway, here is what you do (buy :D ):
- 2x E5420 or E5430, depens on what you want to spend
- Z7S WS :D
- 2 or 4 2GB DDR2-800 FBDimm sticks, depends on whether you need 8GB (I'd recommend it though). Note that you need special ram that runs rather hot (fully buffered dimms).
- 2x EK Supreme for CPU cooling. They work flawlessly with the mobo, you use the supplied metal-frame backplates (NOT the ones you see on page 1) then you can use the normal mounting supplied with the coolers
- one HR-05 IFX + 80MM fan for cooling the NB (it will get too hot with stock cooling and waterblocks on the CPUs)
- Fan to cool the mems
- GFX card matching your preferences, there are some great new cards launched today, but if you don't need the best of the best, get a single HD3870 or a HD3870X2. You can add another one later for a Crossfire setup
- PSU: Get a Corsair HX620 as it will be strong enough for your initial setup, if you plan on going Crossfire soon get something in the 750W range, but don't forget you need an EPS capable PSU (8pin AND 4pin 12V connectors)
You can then OC the FSB from 333 to 400, which gives you 8*3Ghz or 8*3,2Ghz depending on the CPUs you buy. My E5420's run at FSB 430 which is 3225Mhz all day every day, but you need to have some luck with that. FSB 400 will almost always work though.
Let me know if you have any other questions :)
