Thanks for the tip, I have been trying to run +3 on one and stock on two. I'm still reading that thread so shhhhh.... :p:
look at this giga ddr2 P45 chipset board that will come out soon...GEEZ!
CREDIT:... http://www.ocworkbench.com/
Originally Posted by OCW
The heatpipe designs are getting more elaborate all the time. Nice layout I think, I like the slot config.
yeah!...this is what stands out, which peaked my curiosity:
Outstanding cooling design with Pure Copper thermal design featuring Water Cooling
:D are you kidding me...sheez!;)..i never got up that high even with my E8500....i guess my sticks are doing sh*t for me!:p:
this is what i did with my 9650:
http://www.xtremesystems.org/forums/...&postcount=120
EDIT:...here is my best with my E8500 (800 mhz): http://www.xtremesystems.org/forums/...&postcount=233
Ok so I'm not totally on the wrong track... good to know. Thing is a 2x1gb ocz flex kit really can't produce much better results. Maybe it's the cpu, I had a chance to trade for a 9550 and now I'm wondering.
Testbed:
CPU: E8400
Memory: Gskill GBPI PC12800 (1600) 2gb x 2 kit
Mobo: Gigabyte X48T DQ6 Rev 1.1 Bios (F4h)
Gpu: Gainward Bliss 9600GT 512mb Golden Sample
HDD: IDE Hitachi 80gb 7200rpm
PSU: Vantec Ion2 500 watt
OS: XP Pro SP2
Memory is 7-7-7-18@ 2T@1.9vdimm rated by manufacturer
Of course, I am not going to run at manufacturer rated clock speed
900mhz@8-8-8-8-18@2.1vdimm - Pi 32 million passed
http://img232.imageshack.us/img232/4...881821vgh9.jpg
900mhz@8-8-8-8-18@2.1vdimm-01se
http://img215.imageshack.us/img215/4...881821vrc0.jpg
900mhz@8-8-8-8-18@2.1vdimm-03
http://img238.imageshack.us/img238/7...881821vnl3.jpg
900mhz@8-8-8-8-18@2.1vdimm-05
http://img89.imageshack.us/img89/658...881821vlv6.jpg
900mhz@8-8-8-8-18@2.1vdimm-06
http://img171.imageshack.us/img171/3...881821vmv7.jpg
So far, Bios F4h is the best bios for memory oc. Bios F5a and F5d failed to get the memory stable at 900mhz=(.
Here is the memory module
http://i234.photobucket.com/albums/e...w/SANY0134.jpg
I've been having good results and stability with bios F4D so I really haven't tried others for more than just a look. All my benches as well as 24/7 operation running boinc have been pretty much with the settings I posted. I'm never going to get any higher with this or any other board and the x3360's because they won't run past fsb 475 or so.
pretty well 475 fsb is it for quads on air...i think i got to 480 fsb but that was pushing it with voltages...a bit beyond my comfort zone;)
Yes I agree and with all the reading I do I guess I knew it even though I wanted to prove it wrong, lol. It's so much fun to try and beat the odds you know? :D
I have had this plan in the back of my mind for awhile... There's a local tech school that has hvac/hrac courses and a pretty nice shop. My thought is to approach 1 or 2 of the students with the idea of building a really nice 1hp or so ss for me as a school project with me funding the neccessary supplies. Never hurts to try :)
Hi folks,
I'm working on another machine for my office this time. GA-X48T-DQ6 with a QX9770, Quad 15k SAS Enterprise and a Promise SuperTrax 8650 SAS controller; also 8GB of DDR3-1600 memory from OCZ. Now I have the memory passing at least 1 pass and still running no errors, 4x2gb at 8-8-8-25-2T with 900mV CPU drive and "Normal" or "Auto" skew.
I am using BIOS F5C which I found with google. Under BIOS F4 I couldn't even get 1 stick of memory to pass memtest with DDR2-1600 settings, albeit I was trying at 7-7-7-24-2T 1.9V, you know the rated specs for this memory (should have worked, right)? Anyway...
When I go into the BIOS on F5C and try to enable the FSB control, it quickly disables it again. I have absolutely no idea why. I want to try the memory at DDR3-1800 with FSB 450 but maybe this BIOS has a bug in it, can anybody else comment on this? Thanks.
(PS. In my signature rig below I am swapping out the 750W Power for a 1000W power because my Kill-A-Watt recorded 1010W in 3dMark06 peak so don't razz me about that!)
BIOS F5C is flawed for the reason you found. Use F5A or F5D
luck:)
The link to station-drivers has no file found so where can I get F5D now?
Link works for me
see * GA-X48T-DQ6 BIOS v.F5d
It's in the 2nd box down
Gigabyte company released new Bios version for its motherboards
In new version some errors are fixed and work improved
To download bios update choose your motherboard model from following:
* Gigabyte
o GA-X48T-DQ6 BIOS v.F5d
o GA-X48-DQ6 BIOS v.F7g
o GA-EP35-DS3P BIOS v.F4e
This is very strange I cannot get to it:
http://www.station-drivers.com/telec...os/x48tdq6.f5d
Traceroute dies here:
9 17 ms 20 ms 15 ms 68.85.162.58
10 24 ms 35 ms 20 ms 68.85.162.57
11 49 ms 48 ms 50 ms te-0-10-0-5-cr01.newyork.ny.ibone.comcast.net [6
8.86.90.45]
12 48 ms 51 ms 49 ms tengigabitethernet1-4.ar5.NYC1.gblx.net [64.208.
222.57]
13 123 ms 125 ms 125 ms 020G.gsw-1-6k.routers.ovh.net [213.186.32.130]
14 138 ms 129 ms 149 ms 020G.rbx-1-6k.routers.ovh.net [213.186.32.226]
15 129 ms 131 ms 128 ms rbx-34-m1.routers.ovh.net [213.251.191.97]
16 *
Can you send me the F5d file? jking _AT_ prospeed _DOT_ net
Thanks.
MagnumMan u have a PM:)
good job Fugger sorted us out :lol:
Well with BIOS F5D and a little bit of time I was able to get 4x2gb (2 kits of OCZ3P16004GK) running stable under memtest.
FSB 410
Mem DDR3-1640 +.40V = 1.92V
Timings: 8-7-7-20-2T
All other settings on auto in timings
FSB +.20V
NB +.20V
CPU x9 (QX9770) = 3.7GHz (not tuned yet, I hope to break 4GHz...)
CPU at 1.35V right now
CPU Driving 900mV (normally 800mV)
No skew, left on "normal".
Not too bad for 4x2gb dual rank memory these days. The memory does get pretty hot though I would almost recommend a fan right on the memory to help out. They almost burn to the touch when pushed.
I mounted a 40x40x20 fan on the northbridge so it has active cooling (I left the heat pipe solution alone and put a fan over it securely, plugged into the "NB" fan header). The NB is almost warm to the touch near the base when running memtest. Before the fan it was getting almost too hot to touch.
Anyway so far so good. I tried 8-7-7-18 but the system kept boot-looping. So this looks like the best timing I can get with 4 sticks. Good board, seems pretty stable.
my cold start problem went away
it was the damn power supply
p.o.s. Seasonic X900 :down:
Corsair HX620 went in and all is sweeeeeet :D
I finally stabilized a rig with this board. Took more reboots than I thought it would. Here are all the specifications to help people out who may be setting up something similar.
QX9770 Rig Settings and Benchmarks
Mobo: Gigabyte GA-X48T-DQ6 BIOS F5D
Custom active cooling on northbridge heatsink
CPU : Intel QX9770 @ 3.8GHz
Scythe Mugen Cooler (it's huge)
Mem : 2x OCZ3P16004GK (4x2gb PC12800)
Disk: 4x Seagate Cheetah 15K.5 SAS 146GB 15k
Ctrl: Promise SuperTrak EX8650 (800MHz ioproc)
Vid : ATI Radeon 3870 @ 825/1150
OS : Windows 2008 Server x64 Enterprise
BIOS Settings:
CPU Ratio 9.5x => 3.8GHz
FSB Control => Disabled (400MHz)
PCIe Frequency => 110
CIA2 => Disabled
Perf. Enhance => Standard
Memory Multiplier => 4.00D
Memory Frequency => DDR3-1600
Memory Timings => Manual 8-7-7-20
tCL 8 (CAS)
tRCD 7
tRP 7
tRAS 20
Secondary Timings
tRRD 5
tWTR 6
tWR 12
tRFC 75
tRTP 6
tRD 9
Adj 2
CMD 2T
CPU Drive => 900mV
CPU Skew => Normal
MCH Skew => Normal
Voltage => Manual
DDR3 => +.35 (=> 1.88V)
PCIe => +.10
FSB => +.20
MCH => +.35
Load => Enable
CPU => 1.38750V
Benchmark Scores:
SuperPI 2M 29.437s
Sandra XII SP2c
Processor Arithmetic 49990 MFLOPS 64218 MIPS
Inter-Core Bandwidth 22202 MB/s
Physical Disk 251.84 MB/s @ 6ms
Memory Bandwidth 7.91GB/s (int/float same)
Memory Latency 74ns (92.40 speed factor) L1 3 clocks L2 18 clocks
Cache + Memory Bench 59.06 GB/s (56.50 speed factor) L1 321.66 GB/s L2 101.01 GB/s
Everest 4.50.1330
Disk Read
Linear Begin 377.3 MB/s
Mid 335.3 MB/s
End 227.2 MB/s
Random 320.4 MB/s
Buffered 1045.6 MB/s
Access 5.7 ms
Memory Read 8738 MB/s Write 8457 MB/s Copy 8691 MB/s Latency 64ns
L1 Read 60708 MB/s Write 60556 MB/s Copy 121097 MB/s Latency 0.8ns
L2 Read 27559 MB/s Write 20219 MB/s Copy 29482 MB/s Latency 4.5ns
HD Tune 2.55
Burst 397.9 MB/s
Avg 153.0 MB/s
Max 172.6 MB/s
3dMark Vantage 1.0.1.1 P4933 (4024 GPU, 15319 CPU)
can you get to 4 ghz and run any benches?
Unfortunately Core #1 (numbered 0 through 3) dies above 3.8GHz at any voltage and quickly too. Since temps are already 80C (175F) !! I prefer to keep that where it is. Took me 5 days to stabilize this rig, I'm done doing that. This is a development rig for my office which I will be using to build an app that takes over an hour to compile/link on an Opteron 248 (2.2GHz) system. I expect that time to be around 20 minutes with this new hardware. Keys to stabilizing were:
1. running memtest to find the memory stable settings (DDR3-1640 8-7-7-20-2T), anything over that was failing frequency-wise.
2. running prime95 small FFT to isolate the CPU's potential, which seems to be 3.8GHz (this is pretty lame because other people have gotten to 4.0 GHz, so I think I got a bad CPU, but it's still well within engineering tolerance, I suspect).
3. upping voltage on the FSB and MCH, FSB at +.30V locked up the system; MCH at +.40 locked up the system.
4. setting the CPU drive to 900mV
5. Manually setting all the secondary memory timings to be one higher than the auto selection was, i.e. 5 became 6.
The Scythe Mugen heatsink is so large it rests on coils too, which may be preventing it from getting the tightest fit possible on the CPU... 80C seems pretty excessive even at 1.38750V to me. Then again I am used to water cooling (see sig) and this doesn't have it.
