Sorry for the delay in updating the thread guys, it will be getting the attention it deserves tomorrow evening :toast: and thanks to everyone who posted and let's keep it up :)
You've done an excellent job keeping it up so far. Thanks!
List updated :toast: sorry for the delay folks :slap:
And I must holy S@#% jinu117! That is very nice clocks dude
1) Q6600 G0
2) L723A930
3) http://valid.x86-secret.com/show_oc.php?id=275199
4) http://i104.photobucket.com/albums/m...r/Untitled.jpg
5) Dtek Fuzion, PA120.3, YL Mediums, DDC3.2 with Petra's top and MCW-60 on a 8800GTS in on loop
6) 1.45 Bios - 1.432 measured - 1.416 load
7) Asus P5K-E AP/Wifi
No one has the 737A? :(
Alright, my new TRUE arrived yesterday, and I'm just strarting to break her in. Here's my first stable setting over 3.8:
1) Q6600 G0
2) L727B159 - pack date 09/08/2007
3) CPU-Z #275223
4) http://img339.imageshack.us/img339/2034/8hrsil3.th.jpg
5) Thermalright Ultra 120 Extreme
6) 1.575V (BIOS) - 1.536V (with vdroop)
7) Gigabyte GA-P35-DS4 Rev.2.0 f8b
Q6600 G0
L34B164
vcore 1.472
Gigabyte GA-P35-DS4
http://img215.imageshack.us/img215/8...2145614bw5.png
miahallen, very nice :up: What's your ambient temp. Low 60's with 1.54v is incredible. Even with 16-17 ambient I can't beat those at 3.6 and 1.42v.
devious...... HOLY :banana::banana::banana::banana:ING :banana::banana::banana::banana: DUDE!! amazing!
Thanks man :cool: ...I was testing this afternoon with my window wide open...I'm just outside Tokyo and I think it was about 15-17C today. My CPU and my TRUE are NOT lapped yet. But I've been thinking about doing it. Regardless, I am VERY please with this TRUE's performance, it way exceeded my expectations! :D And the AS5 still hasn't even cured yet!
I'd love to see what I could do with one of those low voltage chips, like the L719B series. I'd bet I could get one of them stable at 4GHz...oh well. 450x8 @ 1.45V seems to be pretty stable for 24/7 use, and I can keep my fans turned down for a very quiet rig ;)
CraptacularOne,
Not sure if you want multiple listings for one user, but I don't see why not. If I can find two settings that each work equally well, it may be useful information to someone. So while my 3.8GHz OC above required my fans cranked up to high speed (aka "noisy"), here is my 24/7 setting with the fans on low.
1) Q6600 G0
3) CPU-Z #275223
4) fans on low - front door closed (Antec P180)
http://img99.imageshack.us/img99/909...vlowii5.th.jpg
fans on high - front door open
http://img99.imageshack.us/img99/821...highdq6.th.jpg
6) 1.45V (BIOS) - 1.408V (with vdroop)
This primed for over 10hrs, notice the 10 degree drop with the fans turned up.
Q6700 @ 3.5 GHz (10x350)
1) Q6700 G0
2) L726A915
3) http://valid.x86-secret.com/show_oc.php?id=275637
4) Click for screenie!
http://thumbnails2.imagebam.com/113/f8553d1120067.gif
5) Thermalright Ultra 120 eXtreme w/ Noctua NF-S12 ~1400 RPM
6) 1.41V under load (actually 1.5V bios; 1.46V idle; 1.41V load)
7) Asus P5B Deluxe WiFi-AP bios 1223
I can actually run things quite nicely @ 3.6 GHz, but i don't feel the extra vcore needed is worth it.
New high for me...3.85GHz 8hrs prime95 stable on air! :D
1) Q6600 G0
3) CPU-Z #278333
4) http://img353.imageshack.us/img353/8...5ghzeo9.th.jpg
7) Gigabyte GA-P35-DS4 Rev.2.0 f9b
List will be updated again tomorrow evening folks, keep those results coming :)
@ miahallen, if it's a different chip then sure you can enter as many as you like, but if it's the same chip I will just update your first entry :)
3.6ghz 9+ hours prime.
1) Q6600 G0
2) L737B063
3) CPU-Z #278324
4) below in attachment
6) 1.304v Load
7) Asus P5k Deluxe
Don't know if you'll count this one cuz its a short prime but I already sold the cpu so I can't re-prime it but i assure you it was stable.
Xeon 3220 ES @ 3.6ghz 5min prime
1) Xeon 3220 G0 ES
2) dun rmb whole batch code but it was L717A
3) CPU-Z #277804
6) 1.33v Load
7) Asus P5k Deluxe
L734A857
Pack: 10/5/07
Anyone have any information about this batch?
1. QX 9650
2. L739A640
3. 1.34v Vcore
4. Watercooled
5. Asus Maximus Formula SE
http://aycu03.webshots.com/image/342...5847358_rs.jpg
Ok I have a brand new (retail box) L737B on the way. I'll post results when it arrives. Going to run it on an ASUS P5K Premium board.
Q6600-GO
L727A918
http://valid.x86-secret.com/show_oc.php?id=280286
Cooling in sig
1.65
evga 680i
http://members.aol.com/Mm2246220/images/Q6600_1.JPG
http://members.aol.com/Mm2246220/images/cpuid1.jpg
Only 2.5 hours prime..but I'm going to try for 4GHz+, if I can't make it I'll post up an 8 hour prime run.
