black matt!
black matt!
My contribution:
http://img263.imageshack.us/img263/7...76largeoz7.jpg
http://img185.imageshack.us/img185/7...73largebk7.jpg
http://img175.imageshack.us/img175/6...00largexn5.jpg
http://img296.imageshack.us/img296/5...80largebn6.jpg
http://img127.imageshack.us/img127/8...87largedx9.jpg
http://img239.imageshack.us/img239/8...88largery4.jpg
http://img151.imageshack.us/img151/7...84largebx2.jpg
http://img242.imageshack.us/img242/2...94largeso8.jpg
http://img185.imageshack.us/img185/6...96largelv8.jpg
There are some awesome rigs in here, too many to mention but I wish I had bought the 2000 or the 1000 plus as I can't really do much else with mine, damn pa120.3 is huuuge. I moved up to 4gb since the pic.
Could put than put the rad on the roof and get space for X2 CF... Hmmm...
Keep it up and I'll be popping in from time to time to drool
My new Alphacool 120mm rad in my rig:D
http://img111.imageshack.us/img111/883/97075985lt4.jpg
Machined :) , not by me :)
I just got my v2000 a few days ago, and I've been wondering whether or not to use the duct. I know if I use the duct, then the fan should be intake; right now I'm not using the duct and the fan is exhausting.
I'm using the stock Intel cooler until WCing in a few months. Until then, should I use the duct? Should the fan be intake or exhaust? Should the duct be at more of an angle, or should it run alongside the side of the case?
Full size;
http://img240.imageshack.us/img240/2796/11ei0.jpg
@ Rockford, that is utter beauty! Are those silverstone fans? What kind, cfm, noise etc? I like it a lot more than your avatar rig, and I loved that one as well!
Thanks;)
Fans are Silverstone FM123:
http://www.firebal.net/asp/show_stoc...duct=SST-FM123
106cfm max:D
@ RockfordFosgate I'm considering doing a similar setup, and I was wondering what kind of temps are you getting.
I would like to know the temps for everything eg. load/idle temps for CPU, GPU, NB, and SB.
Ok so i know that this isn't a Lian Li per say but technically it's the same case. it's a Tagan Black Pearl which is pretty much an exact twin of the V2000B.
http://i23.photobucket.com/albums/b3...s/P1014725.jpg
http://i23.photobucket.com/albums/b3...s/P1014740.jpg
http://i23.photobucket.com/albums/b3...s/P1014757.jpg
r those raptors 150's at 45 degree angles?
Hi can anyone on hear tell me how i can mount my hard drives to the dvd slots at the front of my lian li 2100b. can you get the mounts used on the Fusion LQX Cepheus Q80
beatiful tagan case
I'm not too sure about the exact model he used in the Q80 but the silverstone drive cage is pretty similar:
http://www.newegg.com/Product/Produc...82E16811999164
I would love to have 2 V1000's together but cost and mobility limit me. In the future hehe, till then I'll just enjoy looking at yours
Feser Black of course
All your cases are so sweet.
Anyone selling? I'm buying! :D
me . . .
