That's a nice vcore for a ccb6f yeah. BTW, did you learn anything about the vdroop issue? Saw you asked at vrzone too.
@ Badnizze: looking forward for some awsome oc's from your 6400+ ;)
somebody better jump on this
http://img146.imageshack.us/img146/9...1233016pi1.png
nice deal.
Love the way you'repriming away in the backround there msi.
Just started testing my 6400+, primed thru night at 3360mhz, @ 1,45 -> testing some mhz at 1,43V know. Stepping is CCB8F 0718 MPMW, Booted win and did runr prime for a coupple of mins @ 3450 with 1,43 ;) I have probelms with coretemp, keeps crashing my system... So no temps as of now... Must get to work know!
why the hell i didnt receive any notification about this thread??
anyway, good results. have anyone played with drive strenghts?
Mines a wk29. (ccb8f 0729)
stock 1.4v @ 3.3ghz
3.6ghz doesn't load windows no matter what. :p
Board is an MSI K9N Ultra.
Super pi 32m :
(*Edited*)
http://i76.photobucket.com/albums/j3...435_spi32m.jpg
Nuclearus 9280 :
http://i76.photobucket.com/albums/j3...35_nuclear.jpg
Nice clon22. Do you have the rest of your stepping? What's your max oc? Getting them beyond 3.3GHz without having to up your voltage drastically is usually the problem with these.
Yah, thats the problem...
This is my proc :
http://i76.photobucket.com/albums/j3...000/6k0729.jpg
Highest, still under 3.6ghz.
It can boot even @ 3.7ghz but @ 3.6,
it juz fails to load into windows... :p
hehe I wouldn't call that a 'problem' clon, It's a CPU arch stretched beyond it's limits. I haven't seen a signle chip do 3.4 on stock volts so don't fret.
These chips are amazing for a K8 so just be content with that.
It hit home how far these things have somehow managed to come as far as clocks go when I started OCing an E6750 on the weekend as part of a competition. It fell over at 3.35gig and 1.35v and i felt a sense of "oh crap, i've got a bad chip/batch, just what i need" Then realised, no it's actually quite normal, but just 6mths ago it was a case of Core 2 scaling much further on stock volts than ANY K8 I was subconciously expecting some miracle frequency before it fell over.. it kind of made me realise that if it wern't for the fact K8 is a slug in comparion clock/clock they would be really quite attractive :)
The key difference here though is that core 2 scales with voltage beyonf that point like a dream, whereas the old SOI just won't.
Ok, here's the specs. :)
Validation : http://valid.x86-secret.com/show_oc.php?id=243268
*Updated.. sorry :)*
6000+ ccb8f 0729epmw
1.6v in bios
On h20 using swiftech apogee am2
24/7 on stock cooler @ 3.25ghz(250x13) @ 1.4v
http://i76.photobucket.com/albums/j3...35_validat.jpg
Nice results all! Thought Iīd give prime a go at 400*8 ram 1:1 3-3-3-8-14 2T
works nice! Getting a 6000+ tomorow to test!
Cpu, v-core 1,425 bios 1,408 load.
Ht-link 1,2v
Chip: 1,67 (1,5 deafault)
Memory 1:1 3-3-3-8-12 @ 2,2V
http://i30.photobucket.com/albums/c3...rime1600Ht.gif
Here is the Pi32M of my CCB6F 3800+.
Don't look @ the mems. Corsair MXS5402v7.1 (ProMOS). In fact, they are better than OCZ Flexx. With Flexx SPD i couldn't get 2800MHz stable...
@1.4V with WC: ApogeeGT, Lada heater (old Ukrainian car), ATMAN 305.
http://img116.imageshack.us/img116/7251/3200vy9.th.png
Hey Guys,
Sorry for the slow reply. My DFI 590 died.. so Its going to RMA. In the mean time I put my EVGA 590 board back on the bench, and it actually performed relaly well with the 6400.
The only annoyance is that this CPU isn't recoginzied by the bios.. its says "Unknown"
While I was tweaking the system last night, I ran Nucleus Multicore, and here is my results:
Score: 10319
http://www.ironmods.com/ForumImages/...ore_10319b.jpg
Since the BIOS doesn't recognize the CPU, it shows up as unknown in CPUZ. CoreTemp was able to identify the processor, and you can see the speed via Clockgen. Hopefully the checksum will be adequate to show this is a legit score.
I will try to get an SPi32 MB in the 18min this weekend.
Stay tuned.
Ton
I have to say, these chips are amazing. I have a 3800+ CCBVF. 10hrs stable at 3150 (315*10) 1.42 vcore with a BT. I can boot and validate at 3350, but still not at 3400. I went up to 1.61 vcore, so I may try a bit higher to do a suicide. Not bad for an open box CPU for $57 :)
mine: L723VPMW 0120
watercooling: 3.6G 3Dmark05 1.6v (22c ambient)
DI cooling: -20c loaded, 3.83G 3Dmark05, 3.93G pi_1m.
SS=4Ghz
thread here:
http://www.xtremesystems.org/forums/...d.php?t=160217
Nice nice and nice..
SAD you've crapped all over my nuc score!, good stuff ;)
Victor, you're so close there :)
Very nice! Vikor&SuAsDu
mAJORD:How is youre Dfi 590 for clocking ram? Getting my own 590 next week and I was wondering if I could expect same ram clocking godness as with my P35/N680 borads? My DFI 570 and my Crucial Ballistix donīt like each other...
It's good BAdnizzle.. DDR2-1200 is about it or the CPU's limit,
http://img467.imageshack.us/my.php?i...6666ramce7.jpg
Best @ tight timings ( DDR2-1142 4-4-4-6 @ 4Ghz)
The reason I havent been SS'ing with CPU+mem tabs is for some reason when I'd open the 2nd CPU-Z the system would shut down, and i'd lose it all! this happend twice before I gave up on that. So I did that run just to show memory timings.
No idea why it started doing that, only does it in the cold (near coldbug) it seems, as I never had the problem before that I can remember, very odd.
Tomorrow is DFI 590Time! Pushing my Ballitix to 450-480 3-3-3-8 with 2,6-2,7vdimm ;) Hoping for 500 cas 3 under 3v....
Looking forward for your results BadNizze
Got my DFI 590SLi up and running now, so far i have not done any serios benches. Trying to find my 24/7 setting for know. 300*11 @ 1,44idle\1,424 load. Ballistix @ 1:1 3-3-3-8-12 2,2V It did pas 8houres of prime blend, but i tightend up my subtimtings soo i will do another 8+ houres of prime know, Just to be on the safe side... My only concern soo far DFI is, WHY did you remove the bulit in memtest WHY? Will uppdate with screens as soon as i gett up in the morning! :wave:
UPPDATE: My overklock pased Prime95 Blend test over night! Sorry you can´t se my subtimings... Need to resart before I can open Memset...
Sreen
http://i30.photobucket.com/albums/c3...ic/Prime-2.gif
