Same here, kinda out of money for any additions to this project
at the moment
As with anything, I am still learning about water cooling - didn't even know about rpm monitoring of a pump, hence me going for the MCP655 (which seems like a great pump, just never had anything to compare it against in actual installations :p: )
I'm kinda big on automation, so if I was to go down this track, is this what I would need:
1. Big-NG
2.
Sensor Hub
That's it?
3. Do I need the T-Balancer as well?
4. If I got the mini-NG, am I right in assuming that it is series into the mobo power switch from the front of the case? Also, would this replace the need for the Sensor Hub?
Also, what would be the most cost effective solution based on the above?
