A noobie question~
Where do I find information for Week and Code?
And what do they represent?
A noobie question~
on the BOX and on The CPU itself. ;)Quote:
Originally Posted by Garu
User Name: vafan13
Stability: 8 hours Orthos blend
CPU: Xeon 3060
OC: 3500mhz
Stepping: 6 B2
Week: ?
Code: ?
Vcore: 1.3v
Cooling: Air
Cooler brand/model: Sunbeam Tuniq Tower 120
Motherboard: P5B Deluxe
Bios Version: 910
Operating System: XP 32
RAM brand: CellShock
RAM rated speed: DDR2 PC 8000
RAM actual speed: 500mhz
Latency: 4-4-4-5
http://img240.imageshack.us/img240/2404/oc35ed7.jpg
User Name: Vinas
Stability: 9 hours + Orthos
CPU name: E6600
OC: 3700MHz
Stepping: 6B2
Week: L628
Code: A268
Vcore: 1.6250v
Cooling: Air
Cooler brand/model: Scythe Infinity (dual fan mod)
Motherboard: Gigabyte GA-965P-DQ6 rev. 1
Bios Version: f9
MCH: +.35v
FSB +.25v
PCIx +.15v
Operating System: Windows Server 2003 Standard, 32 bit
RAM brand: Gskill
RAM rated speed: PC6400
RAM actual speed: 924MHz
Latency: 4-4-4-10
Vdimm: +.400 (2.20v)
http://www.voanet.com/tmp/orthos%203.7GHz.jpg
CPU Name : Xeon3060
OC : 3600 MHz
Stepping : 6 B2
Week : L630
Code : A986
Vcore : 1.55
Cooling : Air
Cooler brand/model : Thermalright HR-01 + Thermaltake Smart Case Fan 120 mm
Motherboard : Gigabyte GA865P-DS3P (Rev. C2)
Bios Version : F4
Operating System : Windows XP 32 Bit
RAM brand : Kingston
RAM rated speed : PC4300
RAM actual speed : 800
Latency : 4-4-4-5
http://valid.x86-secret.com/show_oc?id=170102
http://www.uppic.net/io/orthos11hr.jpg
thanks guys keep them coming :toast: ...
Updating now
updated.. come on we want to see some 4300 and the newer week 37's keep them coming :toast: :woot:
Originally Posted by Pt1t
you forgot me in your update
OCCT don't stress CPU/RAM like Orthos.
I test it. OCCT tell's me that I have stable system after 30min test (priority high). After that I run Orthos and at about 5min my CPU temps are ~5C higher than OCCT, at 10min crashes (not stable system, low voltage).
GrimReaper - don't put OCCT for testing in this thread
User name: SaII
CPU name E6300
Stability: 15hr orthos blend
OC: 3450
Stepping: 6 B2
Week: L628
Code: A 190
Vcore: 1.44
Cooling: air
Cooler brand/model: Tuniq Tower 120
Motherboard: Gigabyte DS3 Rev2
Bios Version: F10
RAM brand: Crucial
RAM rated speed: 5300
RAM actual speed: 986
Latency: 4-4-4-12
http://img371.imageshack.us/img371/7...lockth5.th.jpg
I hope I can be added to the database. :D
User Name: SmsMasters
Stability: 8+ hours orthos small ffts
CPU: Core 2 Duo E6600 L632B086
OC: 3600 MHz
Stepping: 6 B2
Week: L632
Code: B086
Vcore: 1.43V Steady (pencil modded)
Cooling: Air
Cooler brand/model: Arctic Cooling Freezer 7 Pro
Motherboard: Asus P5B Deluxe Wifi
Bios Version: 0910
Operating System: Windows XP Pro SP2
RAM brand: Corsair
RAM rated speed: PC5400
RAM actual speed: PC6400
Latency: 4-4-4-12
CPU-Z Validation: http://valid.x86-secret.com/show_oc?id=170386
Screenshot:
http://www.imagewire.co.uk/out.php/t...8hrsstable.jpg
update:
User Name: Blackoberst
CPU: Core 2 Duo E6300
OC: 3400 MHz
Stepping: 6 B2
Week: L628
Code: A221
Vcore: 1.408v
Cooling: Air
Cooler brand/model: Scythe Mine
Motherboard: Asus P5B Deluxe Wifi/Ap
Bios Version: 1004
RAM brand: Kingmax
RAM rated speed: PC4300
RAM actual speed: 972Mhz
Latency: 5-5-5-16
http://img99.imageshack.us/img99/6359/3400regp6.png
Wwaaaaaaaahhhh...what about mine?Quote:
Originally Posted by GrimReaper
OK here's a new one at 3.6Ghz. My next is going to be 3.8+Ghz after I lap the cpu and put in the 150cfm delta (I will also let you know then what my week and code are so you can add them in).
User Name: vafan13
CPU: Xeon 3060
OC: 3600mhz
Stepping: 6 B2
Week: ?
Code: ?
Vcore: 1.35v
Cooling: Air
Bios Version: 910
Latency: 4-4-4-5
http://img89.imageshack.us/img89/8466/orthos3600fk5.jpg
thanks for the update.. GrimReaper :D
Running Orthos tonight, will post tomorrow once I hit 12+hrs. I know it is stable just don't have a screen shot but here is my info till I get my screen shot up, cpu-z validation in signature.
CPU name E6600
OC: 3375 Mhz
Stepping: B2
Week: L632
Code: A649
Vcore: 1.35 bios set, actual 1.288
Cooling: Air
Cooler brand/model: Zalman 9700 + AS5
Motherboard: EVGA 680I Sli
Bios Version: p24
Operating System: Xp Pro
RAM brand: Corsair
RAM rated speed: PC2-6400
RAM actual speed: 750
Latency: 4-4-4-12 2T
Username: vorpoxtrm
Stability: 9 Hours + Orthos Blend, Priority 4
CPU Name: E6600
OC: 3712 MHz
Stepping: 6 B2
Week: L636
Code: A355
Vcore: 1.4875 V
Cooling: Air
Cooling Brand: Sunbeam Tuniq Twr 120
Motherboard: Intel D975XBX2
Bios Version: 2333
Operating System: XP 32 Home SP2
RAM brand: Patriot
RAM actual speed: 825
Latency: 4-4-4-14
Max on CoreTemp (both cores): 69 Deg. C.
http://valid.x86-secret.com/show_oc.php?id=170775
This forum has been quite helpful. This is not the greatest OC, but the information provided here saved a lot time and frustration. Thanks everyone.
billdavis
CPU name: E6600)
OC: 4103.9MHz)
Stepping:
Week: L629
Code:b???
Vcore: 1.6
Cooling: phase
Cooler brand/model: jinu117
Motherboard: Abit IN9 32X MAX
Bios Version: beta 6
Operating System: vista 64bit
RAM brand: Crucial
RAM rated speed: pc2 530
RAM actual speed: 497.4
Latency: 5-4-4-12
http://i107.photobucket.com/albums/m316/wcd26/oc-1.jpg
________
MAXIM XJ750
CPU : E6400
OC: 3480
Stepping: 6B2
Week: L28
Code: A457
Vcore: 1.465
Cooling: Air
Cooler brand/model: Tuniq Tower - 120
Motherboard: Asus P5W-DH
Bios Version: 1901
Operating System: XP 32 Sp2
RAM brand: GSkill
RAM actual speed: 870
Latency: 4-4-4-12
Back in Black... black being the Intel badge on my case.
http://www.maximumoc.com/img/hardware/E6600/1692x9.jpg
Day 1 new vista rig, figured I'd throw my 2 cents in. I came here for some voltage info to see what kinda range these have since this BIOS is so absurd on the voltages it lets you use. This was my highest benchable speed for the night, pretty impressed by this proc. EDIT: just use this for reference.. I don't have the time to run somethin for 8 hours. The point is, the 6600 overclocks like balls.
System info:
Asus P5N32-E SLI
E6600
2 x 1GB Corsair Dominator PC9136
Zalman 9700NT
XFX 7800GTX
User Name: Sysfailur
Stability: Hexus Pifast, Super_PI, Sandra Suites
CPU name: E6600
OC: 3804
Stepping: 6 B2
Week: L640
CPU Coding: SL9S8 Malaysia
CPU Voltage: 1.675 in bios, 1.575 reported
Mem Voltage: 2.150 bios/reported
Northbridge Voltage: 1.45 bios/reported
Cooling: Air
Cooler brand/model: Zalman 9700NT
Motherboard: Asus P5N32-E SLI
Bios Version: 0602
Operating System: Vista 32bit
RAM brand: Corsair
RAM rated speed: PC9136 (1142mhz)
RAM actual speed: 1128
Latency: Bios all auto 5-5-7-28
your CPU throtle... can't be considered as stable ;)Quote:
Originally Posted by Friday~13rd
My L632B173 is currently undervolted because I'm stuck with stock coolers (stuck coolers?) This is the max (at least 2hr. stable) on 1,1v. Once my waterblocks arrive I'll be back here with some better results :)
http://img03.picoodle.com/img/img03/...tm_cd34007.jpg
User Name: Balazio
Stability: Orthos +8h
CPU name: E6300
OC: 3500Mhz
Stepping: 6 B2
Week: L633
Code: B063
Vcore: 1,400v
Cooling: Air
Bios Version: 1004
RAM brand: Team Group Xtreem
RAM actual speed: 1000
Latency: 4-4-3-4
CPUz: http://valid.x86-secret.com/show_oc?id=172262
http://img134.imageshack.us/img134/287/orthosxj4.th.jpg
UPTADE SCORE with my new watercooling system :woot:
User Name: Atrin
Stability: 10hours Orthos
CPU Name: E6600
OC: 3532 MHz
Stepping: 6 B2
Week: L632
Code: A391
Vcore: 1,44
Cooling: Water
Cooler brand/model: Aqua Cuplex XT
Motherboard: EVGA NF680i SLI
Bios Version: P24
Operating System: WinXP Pro SP2
RAM Brand: Crucial Ballistix
RAM Rated speed: PC6400
RAM Actual Speed: 836
Latency: 4-4-4-12
http://img300.imageshack.us/img300/6...v10saatvs1.jpg
i will try 3.65ghz later..
When will I be added to the list. Thanks! :)
