Ballistix tracer pc2-8500 2.3v on a p5k deluxe:up:
Just screwing round with my 2x1GB PC6400 Ballistix and got it up to 610Mhz on 2.2V. I probably can get the timings tighter but haven't really tried yet.
http://img378.imageshack.us/img378/8...clubcl9.th.jpg
*Also could not use SuperPi Mod because it only runs when I have other apps open and then of course it runs slower... Vista :(*
Teamgroup Xtreem PC2-6400 - 5-5-5-15 - 2.3vdimm
http://img243.imageshack.us/img243/9331/pimg0.jpg
hi sorry the offtopic butwhich one will get better overclocking with 4gb?
tg 6400c3
ballistix 8500
cellshock 1000c4
1300 with 2.55 2gb i cant believe that with 2.5 1200 isnt possible :D
just did this though. just decided to test the ram a bit.
http://img233.imageshack.us/img233/9016/252ym6.jpg
Did a quick test with My Crucial ballistix Pc5300 http://valid.x86-secret.com/show_oc.php?id=216527 2,5V-dimm ;)
now running at 1200MHz with 2.3V in CL5 :)
A-DATA 4 preZident!
Join again with Team Xtreem PC8500C5 2 GB Kit, and Gigabyte P35-DS3 Mobo
CL 4-4-4-12 @ 2.8 volt 613 MHz Dual Channel Mode
http://img113.imageshack.us/img113/9...7613cl4dw6.jpg
Huh i don't have screen shot as i'm running 16M Pi on benching machine but it does:
600 at 2.3v 6-6-6 ( for now ) with 2x 1024 Dual Channel, Crucial Ballistix PC5300( got 10 of these ) from www.komplett.co.uk.
I'll try them now with 5-5-5 same v.
Update !
They does 5-5-5 with 2.4v
Why not :D , join this club ei ei :clap:
Crucial Ballistix 8500CL5, 10th Anniversary sticks:up: & DFI P965-S DARK:up: :up:
Less Vdimm & Tight on timings test ei ei
Ended up @601MHz DDR1202, CL4-4-4-4
Vdimm 2.46V-2.47V ( Swing ), 2.450V bios set on DARK
Complete SuperPI 1M, Single
http://valid.x86-secret.com/show_oc?id=224450
Finally got around to benching with a 965 board to join this damn club. Better late than never :D
2GB GeIL Ultra Plus PC6400 CAS3
Volt modded P5B Deluxe
610Mhz 4-4-4-12 @2.55vdimm (DMM measured)
SuperPi 1M
http://valid.x86-secret.com/show_oc.php?id=224768
Just a quick test, still some headroom left in them.
http://forums.pcapex.com/attachment....1&d=1186425174
Ballistix Tracer DDR2-1066 2.35v 5-5-5-15 P5K Deluxe
Buffalo Firestix PC2-8500 2x512M
2.1v 600MHz 32M stable :D
Very nice Buffalo :)
What's results with more Vdimm ?
Mushkin PC8500, 2 x 2 gig set of DDR2.
2.55 volts. Asus P5K deluxe, with bios 501.
untweaked 32M run.
This same ram topped out at 1180 Mhz on the P5B deluxe.
on the P5K Deluxe, it tops out at 1250 Mhz, for 1M.
GSkill HZ PC6400 @ 2.5Vdimm set on P5K deluxe with 501 bios.
@spectrum48
nice results for the Team Xtreme Dark. :D didn't go beyond 2.3v so I maxed out at DDR2-1180 with 5-5-5-15 timings.
andreyang got gskill 800hz to do 600 5-5-5 with just 1.9v in dfi p35 :slobber:
Thought I'd pluck in a pair of Crucial Ballistix Tracer PC2-8500 that has yet to be tested on Asus Commando and see what they can do. On Asus P5K Deluxe this set would of hit 645mhz 5-5-5-15 at 2.20v and 651mhz 5-5-5-15 at 2.3v.
System
- Q6600 B3 ES L632A953
- Kayl Black FrozenSS 1/4HP
- Asus Commando 1404 bios flashed from 1001 bios
- 128MB Gainward FX5200 PCI
- 2x1GB Crucial Ballistix Tracer PC2-8500 cooled by 3x 60x25mm Sunon 23.5cfm Maglev fans
- 160GB Seagate 7200.7 SATA
- Pioneer DVR-08 Burner
- Sony FDD
- 620W Corsair HX620 Modular PSU
- WinXP Pro SP2
On Asus Commando so far at 612mhz 5-5-5-15 6-42-10-10-10-11 at 2.20v bios set.
http://fileshosts.com/intel/Asus/Com...ms_everest.png
2GB G.Skill F2-8500CL5D-2GBHK @ 600Mhz 5-5-5-12 @ 2.24v VDimm (Primestable)
tested on Gigabyte GA-P35-DS4 (Bios F5G)
http://www.muenster.de/~e30pics/Bild...K/Prime-02.jpg
CellShock 9200
shoot 1260 cas4 2.55 bios (p5k del No mod)
setfsb 638 :)
2.55 Bios
http://m1.freeshare.us/166fs642282_th.jpg
http://valid.x86-secret.com/show_oc.php?id=228363
spi 1mb@631 Cas4
http://m1.freeshare.us/166fs649524_th.jpg
