this is not true, if you know the right people, the conroe was there in day 1Quote:
Originally Posted by sierra_bound
Thats all i want to know too, from anyone .. please ?
pretty please :p:
You know Tankguys is a store and not a random noob poster right?:slap:Quote:
Originally Posted by Pjoeloe
He clearly has connections, but he cannot buy stepping 5 ES stuff for 300$ over MSRP off ebay to sell to people.
Hello Devious,Quote:
Originally Posted by Devious
Your question I believe is what we all want to know. The only result I've seen @ 450FSB with unmodded board & retail on conroe 6600 (8 multiplier)was a few posts back. I'm thinking this was done on a prereleased board that has red dimm slots, using a beta bios so therefore I do not think we can be certain @ this time. I will have the board Thursday from newegg but I'm not sure I can have results up before late that night or Friday morning, as I will be off to work shortly after it arrives. Did you want 450FSB set in bios or using Guru utility?
yes I was aware of that, and I was talking about B2 stepping.Quote:
Originally Posted by fhpchris
Guys,
the 1:1 divider problems with my OCZ XTC Gold 6400 sticks (Elpida) are gone now. Tony kindly investigated this problem and coded a new SPD which he asked me to test with my sticks. It works like a charm now :)
Just running stock first, gonna check out what they can do later.
http://img234.imageshack.us/img234/9339/oczoy5.jpg
Great job Tony! :toast:
:D nice to have the pros here . good job tony
It would be even better if Abit got the bios fixed. ;)Quote:
Originally Posted by vanovich
Yeah. That and a 1333 strap would rock for the next update :)Quote:
Originally Posted by bingo13
I have the OCZ Plat 6400 2gb sticks. It should work just like the Gold right?
AFAIK it has Micron D9 chips, should work even better than the Gold ones.Quote:
Originally Posted by amx
Super PI 32M benchies from hardwareluxx.de chaps.
Systems used:
6600ES (Step5 B1) vs. 6600 retail
P5WDH vs. AW9D-Max
Both overclocked to 9x400, both with 2GB RAM running 400 4-4-4-8
P5WDH @ 14.39M
AW9D-Max @ 14.28M
It has been asked for more times than you can imagine. :DQuote:
Originally Posted by Sicness
back in stock at ZZF for 219.99
is there a cold boot on the board??? Like the Asus boards cause im not happy with that. everytime a bios tweak the mobo have to shut down. Bad for my components
I posted this link before but not in this topic, www.anandtech.com loves this board even it was a beta they tested : http://www.anandtech.com/mb/showdoc.aspx?i=2829&p=7
The abit doesn't have that problem.Quote:
Originally Posted by sladesurfer
No cold boot issues at all for me to -50c, one of the reasons I avoided the other boards with that problem besided the DH having only 3 SATA ports when I needed 4 on the ICH7R.
This is a huge plus for those running phase 24/7.
No matter how well this board clocks when it arrives, I doubt I can use it to replace my P5W DH. I have Zalman vf900's on my graphic cards and I need a pci slot for my sound card. Only choice would be to run one card & no sli which I will not do as an avid gamer with a large LCD. That said, I'm still excited to see how well this board is gonna perform.
I just placed it. Yay for free cheaping. So far better deal then eggyQuote:
Originally Posted by eleclipper
I don't think he was talking about the cold boot problem as most of us know it. I believe he was referring to the temporarily PSU shut down after you exit the bios.Quote:
Originally Posted by FUGGER
what is the max FSB on "AIR" with this board?...state which processor...thanks
The PSU does not shut down when you exit bios but that problem may arise when the 1333 strap is introduced. It may require power cycle to switch to that strap.
I hope that won't be the case, otherwise I would have bought the new ASus P5W64 instead since it clocks waaay higher out of the boxQuote:
Oh no, the Asus problem has problem with FSB over 333 and shutting down on reboot. Nothing like that problem, your safe.
