Same here. It's always tried to restart then it just sits there with everything running but doesn't boot the same way it does after a really bad OC.
my ram only likes 0507 bios, any other bios it wont pass dual superpi 32m........anyone else have this problem?
hehe, i thought i was the only one. and I really thought my mobo was dead- atleast the bios.Quote:
Originally Posted by Kashath
Anybody know what PLL to use for Clock Gen?
Also where in the bios do you set your memory for 1:1 or 4:5 plus what is that? I took back the OCZ Gold 800 and picked up the Platinum. The gold was 5 5 5 12 and the Platinum is 4 5 4 15 which was better?
CY28551Quote:
Originally Posted by RDTS
Any step by Step help?Quote:
Originally Posted by hokaro
CY28346 is the only CY I can find?Quote:
Originally Posted by dinos22
You need the latest beta for P5B-D support
just search XS there is an actual thread with this beta
...i am overclocking with bois 0614 and fine and dandy dadda dee 450-500mhz perfect stable..then i go play some games and its a little jumpy....so i run 3dmark05 and i get 5k with a 7900gt... LOL so i check cpuz and this board has me at 1x frequency.....is this just a bug with this bios version or what? i have overclocked with older versions too and it only cripples performance at monster FSB. IT REPORTS IT FINE AT LOWER FSB!! Has ANYBODY seen this before? and DUH yes i have it in the blue slot. i have tried both southbridge modes in bios.
EDIT - UPDATE i tried bios 0507 and same thing am i missing something? even rivatuner diagnostics reports 1x selected as my bandwidth speed........
Guys...hope you can respond quickly.
Put my sys together E6600,Asus p5b deluxe,supertalent 6400,seasonics s12-600..wnet into bios,changed the date and the usual bollocks but after it posted there was a long pause and just a blank screen before attempting to load windows...nothing came so i rebooted and NOTHING.
The lights from the mobo come on and the fans work for the vid card and the cpu heatsink,bnut nothing other than that.
Done all the usual crap,reseated,cleard CMOS..blah-de-blah.
any ideas?mobo dead? :(
Try turning off the psu, resetting the cmos, then try to power on.
Mine is having a similar problem, and will not post unless i do that.
Also, is your board wifi or Ai lifestyle ?
WI- fi...ive tried all the usual stuff,still no post.
guys, any of u know whether the red sata port does effect oc or not ? :D i have 2 hdds (WD 320gb sata 2 & WD 300gb sata) i put the 320gb at sata port 1, and the 300gb at the red sata port..
I don't have any issues overclocking. And you'll see what I have:
http://s40.photobucket.com/albums/e2...04/th_Pic1.jpg
My only problem is my XMS2 EPP, S.O.Bs. won't go above 450mhz.
Offtopic, but where did you get youre tower 120?Quote:
Originally Posted by Nasgul
SO i just called fry's to see if they had the Wifi, so i could exchange my Ai edition, and apprently all the P5B-D's have been "Returned To Vendor". Is this a recall? And hopefully getting replaced with the new C2 965's ??? I'm going to get a refund on mine and see if anyone knows whats up on that.
Returned? Hmmm...
What's so great with C2's 965?
Is there a recall on the P5B-D's mines gone bad??
i'm going to buy this board and a pair of ballistix pc6400 1gb sticks, which are available for a reasonable price here in italy...has anyone experienced any compatibility problem with this ram modules and p5b del. ? ( no posting, required a bios update etc. ... )
can someone explaine how to divide between C1 and C2 ?
i wanna buy the deluxe version in next time.
I just today got my P5B D non wifi. Before that i got DS3. Now i have folowing problems. My Asus 7950GX2 is working with very low performance on P5B D. It's like just one card working. I was trying to reinstal nvidia drivers. Than VGA performance inpruved, but just for ~ 2 min. Than again very big drop in FPS. If on DS3 i was running 3dmark 2006 and in first test i got ~ 30-40 fps than on p5b d ~ 5-15 or somethink like that. Anyone got any idea what to do?
My setup:
E6400
P5B Deluxe (O614 bioss)
2*1024 Teamgroup DDRII 3-4-4-8@667 mhz
FSP 700W PSU
P.S
I just tried to flash 0507 bioss and now pc even dont boot up:(
loosen the mobo screws. you have maybe tightened them to the case too hard... first try unscrew all and power on... and when it works, tighten them one by one but not too hard...Quote:
Originally Posted by thebeast
I have a possible fix for the double restart issue with p5b deluxes. What fixed it for me was lowering the fsb. Setting the fsb to 379 or below using the 1:1 memory strap seems to stop it from happening.
I have tried using other memory straps and it will double restart so I can only say that this may work with 1:1
This was tested with the new 0614 bios, I can't say if the results will be the same for other bioses.
NO1B4ME; I got my Tuniq Towers back in April, $60 each.
I don't recall ever seeing ASUS releasing a new board revision of the same model. If they have, I haven't seen it.Quote:
Originally Posted by fatty
As far as a recall on the P5B-Dlx? I don't think so, mine and every ASUS board I've ever had, has run flawlessly and has there ever been a MoBo recall from ASUS? Not sure about that one but I don't think so.
I haven't heard of a C2 rev coming out but I have the C1 and it's a kickass overclocking board. My only problem is the RAM, it won't go higher than 450mhz, so I'm stuck.Quote:
Originally Posted by LisijBOB
