same here !Quote:
Originally Posted by dogsx2
when i change vdim to more than +0.3v it shows "Fail" in front of DDR 18v :(
i've got Gskill 6400HZ
same here !Quote:
DDR Fail is a normal MBs response to not having exactly 1.8V @ ddr2.
Nothing to worry about
so why DDR 18v is OK when i choose +0.3 so 2.1v ... ?
That's what I'm thinking when I read the answer.Quote:
Originally Posted by geof
and it's strange because i can push my 6400HZ higher with 2.1 than higher vdimm so it must have some importance
the same for you dogsx2 ?
I'd know if this mb is fully compatible with Windows 2k3 server?
I've strange results with Superpi 1mb...
9xQuote:
enabled
400
100
diabled
2.00
800
manual
4
4
4
12
auto
auto
auto
0
auto
normal
+0.2 vdimm
+0.1
+0.1
+0.2 MCH
1.5000
1.325
auto
Ive have placed a fat north bridge heatsink on the nb, and also 2 silent fans on the nb heatsink and south bridge. That helps alot ...
2.1 in the bios and pushing up the volts with ET.Quote:
I can't pass 300 htt boot with e6600. With same setting and 1.6v I could reach 465x8 with an e6400.Quote:
Originally Posted by kiwi
I am so pissed I cant solve this! I even tryed to lower e6600 multi to 6 and still doesnt boot beyond 300...
I'm getting errors in memtest and bad_call_pooler blue screen in 3dmark05 with my 2x1GB OCZ PC6400 EL Platinum XTC. Vdimm is set to +.3. Have tried using both sticks seperately and in different slots; getting the errors regardless.
Any ideas?
Question about OC'ing failures. What does it mean if when running dual prime the computer just hard locks with no prime errors? This happens to me a lot, but at other settings when my vcore is to low i get rounding errors in prime and it fails gracefully.
i'll try this , thanks a lot ! :toast:Quote:
Originally Posted by Pjoeloe
My DS3 board and 6400 should be in tommorow. I am getting 2 gbs of the Gskill Hz ram.
If the board does boot up with one stick, I do need to change dimm to +.3 to give it 2.1v, right?
:( I also have a fortron power supply, crossing fingers.
Originally Posted by slatr
Its strange but with BIOS F4 Oficial and vdimm auto, easy tune reads 2.1v!
Thanks Monk
My backup plans are cheap memory to boot up and update the bios and a new power supply.
UGH I don't want to spend any more money right now, I hope I need neither
no pb here with a Fortron epsilon 600W ;)Quote:
speedfan reads 1.9v ... ( 1.8v with others bios )Quote:
Originally Posted by MonkSP
Where in Easy Tune does the vdimm display? Or do I need to d/l speedfan to get an accurate reading?Quote:
My BIOS settings are @ http://www.xtremesystems.org/forums/...&postcount=282Quote:
I can post 375x9 and get into Windows but my temps are too high...
somebody who can tell what this does in the bios and if they must been enabled or disabled for best overclocking ? :)
- Limit CPUID Max. to 3:
- No-Execute Memory Protect:
- CPU Enhanced Halt (C1E):
- CPU Thermal Monitor 2(TM2):
- Virtualization Technology:
- Robust Graphics Booster:
- C.I.A. 2
Dude, no offense, but :banana::banana::banana::banana:ing read page 1.Quote:
so as me you can't boot over 375 :(Quote:
Originally Posted by Ribbon
i have a 80mm fan on nb and it never goes above 35/40 in load so i think it's not the pb
i'll try to put a fan on sb too as Pjoeloe did , it's the only one who can boot 9*400 in air ...
but with coef 8 i can boot with 8*430 ... ( i prefer to stay with 9 because of my machII gt i will use soon )
What you are seeing with the multi's is the DS3 and the E6600 not playing nice together, since you can do 430*8. Unfortunately, probably the only way you will get any higher is to get a different board.Quote:
FYI I have no issues with any USB devices. Logitech G15, MX518, Joystick or Belkin N52....they all work fine at 429Mhz
i know ...Quote:
Originally Posted by korruptedone
that's why i'll try a P5B dlx soon and a P5W-DH later .
But with my DOD i need a mb which can handle high fsb and that's why i choose P965 instead of 975x ( which is better for big multi but it doesn't like high fsb ... )
hard to find the good one ...:rolleyes:
