;) Sure - but You have also to put a fan in front of this section to get better airflow.........:)Quote:
Originally Posted by AcUaViVa
:toast:
:toast:
Hey guys, im working on overclocking my week 24 6600 to a stable 3.6. I can boot into windows at 3.6 and everything is fine, i can read emails, browse the web and such (idle temps around 50), but if I try to run Orthos, the computer will just shut off. Im not complaining or anything, I am just wondering why it's shutting down. Is it temperature related (load temps around 61 measured by core temp)? Is it a stability issue?
Im away from my computer for the week, vacation in north carolina, so I can't really give a detailed report of what my current bios settings are. However I believe: vcore = 1.4275 vmch = 1.5 fsb = 1.4 vdimm = 2.15
and as for other settings, I have disabled whatever has been recommended throughout reading these forums and around the web. Oh my ram is set at 1:1 3-3-3-8. Im pretty confident my memory is sufficient for this (check my sig for the model) and even if I losen the timings, once I run orthos it shuts down.
So far my best stable oc for gaming and 24/7 usage has been 9x356 = 3.2 at a vcore of 1.2875 bios with most of my other voltages the same as I mentioned before, and ram same as I mentioned above. lol, i really want a stable 3.6 though! :D Any ideas guys?
peace
nice setup you`ve got there;)Quote:
Originally Posted by splmann
Guys, Im hoping you can help me out. This is how it goes down!
Asus P5W64PRO Bios 0301
vmch 1.6 vfsb 1.4
Cell Shock 4-4-4-12 1:1
E6600 Week 28 @ 3.6ghz 1.425vbios
My mobo is running 400FSB 1:1 @ the moment. Its rock steady, i know the memory can take upto 500mhz stable cause ive tested. The Cpu is able to do more i just know it! Except everytime i crank up the FSB above 400. I start orthos i just shutdown. Its driving me nuts, i know that the CPU and the memory are fine, what do you suggest for getting more out of the mobo. I ve tried quite a bit...but no luck.. no matter :slapass: what i do during orthos the PC just shuts down and restarts!! :slapass:
Have you try 1.5v for vcore instead?Quote:
Originally Posted by Ibinco
Originally Posted by rithina
yeh m8 ive tried 1.5 1.55 and even 1.6v The CPU can take upto 3.8ghz as ive tried it on another motherboard. Man if this board turns out to be limited @ 400FSB im gonna be well gutted!
Did you try 1.8 vmch?
Your original post states your trying to get above 400fsb using 1.6 vmch and 1.425 vcore.
Icer, Ive tried 1.8vmch aswell.Ive tried 1.8vmch along with 1.55vcore and yet no result. What do you think? do the pencil mod and shoot for more?Quote:
Originally Posted by Icer
Nope it should boot at a min of 450 and clockgen up to close to 470 at least thats my experience with my x6800 so far...Quote:
NOTE: 470 is not stable for me....even at x8 :(
Originally Posted by sdumper
Could you please post your settings as to how u achieved the 450FSB?
These boards are not limited to 400 fsb, I've tried my e6300 on my p5w64 and can hit 420 on with the stock cooler easily, while my e6600 struggles to get there stable. Andre and others have said it has alot to do with the cpu, temps, ram etc etc. Not the board.
Asus masters please give to us new bios with more voltage just for cpu,or ram,or I must go to abit.
Is eny ony one with me?
I thought it might come in handy to pass this url : it`s the newest version of the Asus update utilty v 7.07.06 to update the bios of all asus boards in windows xp without leaving windows xp :
http://drivers.softpedia.com/get/Oth...ty-70706.shtml
Question: where are you finding Bios version 0301 for the P5W64-Pro? Is it a beta? Link? ThanksQuote:
http://www.xtremesystems.org/forums/...90&postcount=1:)Quote:
Originally Posted by Mezzro
I've followed your posts here and have been impressed by the clock speeds you've obtained with this MB/CPU combination. Are you hitting the 4.0 GHz mark through watercooling or just using air? Are you modifying the mainboard at all? Using the same mobo and 6700 processor, I can't get the FSB higher than 333 (with DRAM frequency at 367) and have it stable. I can push it to 370, but it fails Orthos after, literally, running a second or two. I'm using Corsair 8500 DDR2, 1060 memory. Any advice is greatly appreciated. I've read and re-read most of the relevant threads here, but just can't get this CPU to run at 4.0. Thanks
The 301 BIOS link/server is down. Is there an alternative link? ThanksQuote:
Originally Posted by sierra_bound
Link works for me. Do a forum search. You have find someone else whose has a link.
Originally Posted by NickS
How they will be linked?
If you answer to this question..i maybe try it...:D
Maybe i will try 4 x1950 pro...but how will i link 4 cards?
2 is ok...4 will be quad crosfire?
Sierra, this link works for you?Quote:
http://web54.nsi24.miniserver.de/wbb...tachmentid=114
I keep getting "connection timed out" messages. Hmmm
Yes, I just tried it. I was able to download the file.
Does anyone know if Asus is working on a cold-boot fix for this motherboard? Seems like the P5B is the only board they've actually fixed this on.
So far I'm pretty certain that the cold-booting is damaging my kit. I've had 2 fans that have ended up with LEDs that didn't work anymore, plus my Vapochill has behaved strangely a couple of times from switching off and being switched back on (manually) straight away (i.e. USB not being detected, etc).
Worse still Asetek have basically said they're not working on a fix for this as it "only affects ASUS boards". Which means as things stand now when this board does the cold-boot on a normal reset or BIOS change, the Vapo switches off, and motherboard comes back on with no cooling (and then shuts off and complains the next time about overclocking having failed)...
Could someone tell me how to lock RAM:FSB ratio to 1:1 on P5W64 WS PRo?
0215 Bios
:confused: How to lock..........??....?...:confused:Quote:
Originally Posted by Tarkan
CPU-Z telling me the RAM speed is at 2:3
How do i get it to run at 1:1 ?
