Originally Posted by xgman
p4c800 works great. reads everything but voltages.
Touch the heat pipes at the base.If they aren't hot , you're not making good contact.Easy as that.Quote:
Originally Posted by redpriest
What do you mean by "wall"? How stable is it there?Quote:
just in . . . . .
It isn't very stable at 3.733 - dual prime95 causes a reboot in under a minute.Quote:
Originally Posted by Gautam
BTW, Max multiplier is 40.
haha, indeed. 3.466 on air is right about on par with expectations. 3.6-3.8 would be ideal but since so few chips are out, there's no telling what "average" is. I think with water you'd see a nice increase but you'll definately get 4+ w/ your promie. If not, then it's time to shop for memory ;)Quote:
i've heard good things about g-skill... and corsair has the tightest timings of all pc2 6400 but that will run you $400+
Personally, I'm going mushkin:
http://www.newegg.com/Product/Produc...82E16820146108
It actually differs in most cases from chip to chip and board to board. Some are way off, some only a little bit and some not at all as is evident from your post.Quote:
Originally Posted by xxmartin
True, the sensors are normally good but unless they get calibrated its just a accurate scale, with an misaligned dial.Quote:
Originally Posted by NoYd
JUST the guy I wanted to see fire one up!Quote:
Originally Posted by charlie
hey charlie, what's up? ;)
I just hope that I don't have to install a $65 celeron simply to flash my P5WDH. It shipped with bios 502, so I guess I'll see if it boots with the retail stepping. I'll tell you one thing, I'm going to tighten those thumb nuts on my waterblock so the springs look like washers to make sure I have good contact.
0502 is supposed to work with retail conroe
are you using Lga775 socket waterblocks?Quote:
looking forward to see a second "experience" :p:
same ^^
Storm G5 has all the mounts in the kit.Quote:
Originally Posted by noktekniq
I haven't actually seen anyone post this yet. not even Asus could tell me for sure. I guess I'll know soon enough.Quote:
it's in intel forum for a while. i thinkQuote:
Finally, an answer to the mysterious 0502 Bios coming soon!
didnt work with mine, mine was doa.. cant tell if its the bios or not,, FCG hot flashed my chip for me and its on its way back now.
but if it dont work then the board is flat out dead. and im gunna be seriously peeved. and if newegg thinks they are not giving me my money back they got another thing coming.
why wouldn't they?Quote:
Originally Posted by Lestat
So how high is it clocking? :)Quote:
Well, lol, after a failed OC run at 3.733 ghz, the voltage options won't change again, so stuck below 3.466.
Flashed to an older bios and now flashing to a newer bios and then reapplying my itk changes. This is really really annoying.
Thats what you get for using a pile of :banana::banana::banana::banana::banana: board. I just sold my XBX, couldn't stand the damn thing. :slapass:
It's not working again. I wish Intel would stop being overprotective.
