Originally Posted by Primoz78
I used this one on the SB and a different but similar one on the NB. Both a bit of a pain to mount but doable. The SB one has to swing away from any long vid card.
yeah my temps never get over 40 degress stock pate.... Dont use AS5, just a 120mm lownoise over it and the memQuote:
Originally Posted by kenc3dan
Maybe I missed it, but I didn't see any replies to this. I took the plastic film off the covers. I can't see any benefit to them, other than to prevent scratching during shipping.Quote:
Originally Posted by Plaicd
correct... remove these ASAP! Your temps will get very high with these things on.
You maybe wont believe me but...the temps with Thermaltake Extreme spirit 2 are exactly the same as with the stock cooling for tne NB :eek: ...I have checked it twice and have put it on 2 times just to be sure it is good mounted...with no difference in temps...:confused: So I have put back on the stock cooling...Quote:
Originally Posted by xgman
Regards,
Primoz
how did you take measure of your NB ?Quote:
The same as usual...Asus Probe, Speedfan, AI Booster...Quote:
Originally Posted by Mykou
Regards,
Primoz
I think you got Southbridge temp , that's why your temp didn't change after you put the extreme spirit 2 ......Quote:
regards
They`re metal, and yea. they should go. My NB cover is all bent and dented...if I have to RMA, theres enough sticky left on both the cover and the heatsink to reattach, but unless you`re careful, it`ll look like you`ve played football with it.Quote:
Originally Posted by rpr
Hmm....I have this thought too...but the SB tems are the same with ES2 as with the stock cooling...:cool: And AI Booster shows it as NB temps...Quote:
Regards,
Primoz
the south bridge is the system temp probeQuote:
u have to use a laser temp monitor or something like that
Originally Posted by rpg711
Thx for this man...you proved I was wrong :brick: ...I will check the temps with an laser temp monitor tomorrow...thanks :toast:
Regards,
Primoz
lol so have to remount your extreme spirit :p:Quote:
LOL...yes I have to :cool: ...;)
Lp,
Primoz
How come nobody talked about water cooling for P5W DH?
Or fan cooling are the best choice?
Has anyone tried the hot flash method using something other than an intel board. Like an AMD ASUS or DFI ? I tried using an older abit socket A board but got errors.
I have called ASUS, they r sending me a bios, I did pay for overnight but this bios problem pretty much ruined my weekend project & I don't wanna wait til tomorrow.
the thing i hate is always reappling my ac5... its almost empty now... gotta conserve, but when my comp acts up, gotta reseat the heatsink... i hate that :slapass:Quote:
I got a Swiftech MCW30 Wc blockQuote:
Originally Posted by XxHeartxBleedxX
Just waiting for my other Wc stuff to arrive in the mail within the week so ill post my results here
As for VR temps , i have noticed that sometimes the fets are burning hot (the ones on top of the cpu socket) while other times they are just cool
I dont think i want to cut the heatpipe (wouldnt that void the warranty?) so ill be using some CM chipset coolers i bought and put a fan blowing the upper fet area
There's no way that would fit with an X1900 card is there? (which is longer than the Nvidia ones I think)Quote:
At the price it ships , asus should have considered a better layout like foxconn 975 board
If I remember well its layout, southbridge isn't anyway an obstacle to put a 2nd video card if you have a third party cooler over it and they already put an active cooling for the NB...
foxconn boards have a record of exploding lol
I was just talking about their mobo layout lol :DQuote:
Thanks freecableguy, I appreciate the time and effort you put into it, and I'm currently applying the removing the factory compound on my p5w dh. Already did the cleaning last night on the chipset, though I should of checked the thread out earlier when I was cleaning the southbridge, since I literally scrubbed away with a qtip for almost an hour trying to get the thermal compound off the intel & phillipines text, then found the Goo gone step and it worked like a charm. I didn't get to place the Artic silver 5 yet since I scratched the hell out of the bottom of the n/b heatsink, but gave asus a call and they're shipping a new one out to me. Again thanks man, this was a pretty fun new educational experience since this is my first pc build, and also I still have my V'card when it comes to OC'ing. http://www.xtremesystems.org/forums/...lies/toast.gif
Free of charge?Quote:
Originally Posted by TheDro
If not, how much was it?
I've taken the heatpipe off my P5W-DH because I've fitted a Swiftech MCX-159CU, but I wouldn't mind getting a spare heatpipe so I can slice off the heatsink and reuse it (wanna keep the original in case I ever need to send the board back for RMA or sell it).
Ya, free of charge. Should be with the money they're making off of the p5wdh anyway.
