When your system freezes most off the time to low vcore,dram voltage or Qpi/dram core volt.
The first two looks good so how much is your Qpi/Dram Core Volt.
What cooling you using.. your temps!
Your power supply(psu)..i think must be strong enough.
Is your C-State Tech Enabled? this can make it unstable when using higher overclocks -> So Disabled it!
and so on..so we need all your settings to help you!
And guys i still need results from a W3520 for my list :) who give it a try:up:
http://www.xtremesystems.org/forums/...d.php?t=202139
Or any new cpu i'am missing!!
JP.
