Isn't SP2004 just StressPrime?
I think the difference is just the skin, underneath it's just Prime95 but it might be an older version.
Yeah a very old Version. It does not Stress really the new A64 CPUs.
It's just stable for me and my games/programs :fact:Quote:
Originally Posted by Rufus7
just what i thoughtQuote:
Originally Posted by Zeus
so in a few minutes my new 0540 FPBW arrives. Perhaps i can beat my personal best 3250 occt with the previous :) all WC
How high do you guys think it is possible to reach with a 146 CABYE FPMW and DFI nf4 lanparty cooling Prometeia MACH II? That´s my new rig. Mach II arrives on sunday and DFI mobo in a week or so
at least 3.3 ;)
If i currently Have an X2 3800 installed, will i need to reinstall windows to play with my new opty, or should it be okay to just swap them out?
TIA
if its only a cpu swap then youll have no problems ;)
Ya, i was just worried the dual core optimizations/drivers might cause a conflict, but i'll try it out!Quote:
Originally Posted by tatts
I am so excited about my CABYE 0540FPAW! I am hunting for 3.1-3.2 with my shilled setup.
Only question now is to remover the IHS or not before i "de-virginize" it :P
I just removed one on my 146 CABYE 0536GPMW. Load temps of 53C on Water with a Swiftech Storm had me pissed so off it came.Quote:
Originally Posted by UFgatorSean
Load temps dropped 14C to 39C with 1.55v @ 2800MHz.
Be very carefull using the razor blade. I found it much easier to slide the razor blade under the IHS at a corner, more like just pushing it under the IHS. But take care not to slide blade in to far. There are some circuits in there that can be damaged. Just take a look at one some has posted with the IHS off and you will see what I mean.
I'm sure someone else has posted this in this thread before but here it is again. A short movie on the removal. This fella used a razor and a screw driver to pry the IHS off. I didn't like the idea of twisting a blade under the IHS so I just used the razor to cut the sealing material but either will work.
IHS Removal
Good luck!
Not a very good video :(Quote:
Originally Posted by D4nnyOcean
LOL! I was suprised not to see a bloody niblet of finger wrapped in a towel after that!
GPMW ?Quote:
3100..for today :) [IMG]http://img292.imageshack.us/img292/2...31230026nn.jpg[/IMG]
@Rufus7, im now on Prime95 v24.14 and Custom FFTS in place changing every 15 Minutes. (8-4096)Quote:
+8h and running with 3103MHz 1.5V 23ºC ambient AIR, nothing special with Prime :D
So and thats running still yesterday here on my 170 0536MPMW. Ambient Temps between 17-18,5°C.
http://www.bilder-hosting.de/uploads/d4766a9f96.jpg
There is always some dissent as to what is deemed to be an acceptable proggy to show 100% torture stability (mainly by those who's systems are not 100% using Prime95 v24.14 :rolleyes: )Quote:
Originally Posted by Dani
You have a marvellous chip there Dani if you can run Prime v24.14 @ over 3.1Gigs :fact: :clap: , definately a keeper :)
But your first Screen at 3,1Gig and 1,5Vcore under Air is interesting.Quote:
I have an Ambient between 17,5°C und 18,5°C but you Chipset at higher Ambient is lower than mine.
And i have the original DFI Northbridgecooler on Board.
Yours must be modded or under water or your Ambient is below 15°C.
I Would appreciate results from anyone running a 148 CABYE 0543 FPMW :) .
I won't be able to stick any juice through mine for a couple of days and I am curious as to what this stepping can/could do .
Cheers !
in all fairness, 2.5ghz on a 170 isnt much of a OC compared to others and you go on about this prime 24.14 but its only using 50% of your cpu, not exactly tortue is it? :stick:Quote:
At 1.33v its probably could run Prime indefinitely! I want to see something freaky! Show us 2.8ghz and up! :p:Quote:
Yes it's modded, here is a pic of my old setup with tuned VapoChill LS, but I use that NB cooler, 100% copper, fan @ silent :)Quote:
Chipset cooler
..and ambient temp is 22-23ºC ;)
Hehheh, that's true :p:Quote:
Originally Posted by alpha0ne
Thanks mate, should try someday with CO2 :slobber:Quote:
Dani: awesome chip that is :)
Any results with the 146 CABYE 0542FPMW?
