very nice build there mcoffey :toast:
I think its a unwritten rule around here that Horizon owners must have good looking gpu coolers :p: (and nothing looks better than a EK full cover)
I've finally seen the insides of a DD 8800GX, looks crap, no wonder why people say the EK is better. I have one myself and love it
Swiftech Apogee
MCP350
MCR120-QP
MCW-Micro Reservoir
SmartCoils
http://img441.imageshack.us/img441/4389/p1000285as4.jpg
http://img258.imageshack.us/img258/9291/p1000288ye7.jpg
Very clean P180 build :)
Im not sure I follow the bottom hole on the res is going out to my pump. What do you mean????
vicfalc09
Nice setup :)
What temps are you getting idle/load on TAT please and what fan is on the rad ?
Do you guys have any idea what newls1 is talking about in post #3346? Im getting 27 C on core temp, I am using the fan that came with the swiftech kit dont know what kind.
Thanks.
Oh yeah:
I am at 3.2Ghz on a E6400
Another pick from a different angle.
http://img441.imageshack.us/img441/1982/p1000289df2.jpg
he means that the bottom hole of the reservoir should be connected to the inlet hole of the pump
Yeah and it is.
it is not clear in ur pictures to which inlet it is connected so that si why he suggested that
can you please report ur temps using a single 120 rad and also ur system specs
create ur own sig ;)
@ranker: i use a piece of 5mm "clear" plexi with this:
http://cgi.ebay.de/Farbfilterrahmen-...QQcmdZViewItem
it´s very heat resisting.
Finally it is up and running! Need to try to get those air bubbles out :) My CPU idles at bout -5c.
http://www.nvnews.net/vbulletin/atta...1&d=1175503041
http://www.nvnews.net/vbulletin/atta...1&d=1175501627
http://www.nvnews.net/vbulletin/atta...1&d=1175501763
nice -5c , what about load temps ?
Wht type of Coolant do u guys use ??
Some of u guys are just using Distilled water .. is it safe ?? like 100% distilled water ??
Yet another amazing looking 810 build :D
Can u post a pic of ur rad mount, i m building a similar WC like u wiht a PA120.3, Can u post a pic from the bottom of ur Stacker ?? coz i wanna see how u managed to mount the fans n then the RAd :D thx
Here they are. Excuse the dust but im about to re-do my loop with my new FuZion WB, new additives, new res etc.. so why bothering to clean it out right now ? :p:
http://xs414.xs.to/xs414/07141/Picture001.jpg.xs.jpg
http://xs414.xs.to/xs414/07141/Picture007.jpg.xs.jpg
http://xs414.xs.to/xs414/07141/Picture010.jpg.xs.jpg
http://xs414.xs.to/xs414/07141/Picture012.jpg.xs.jpg
http://xs414.xs.to/xs414/07141/Picture015.jpg.xs.jpg
http://xs414.xs.to/xs414/07141/Picture017.jpg.xs.jpg
http://xs414.xs.to/xs414/07141/Picture019.jpg.xs.jpg
I'm actually proud of how i managed to mount the pump :)
PS: If you have questions go ahead.
Thx buddy :D, :banana:
did u do any kind of modding to fit the Rad on the bottom ?? or u just removed the mesh air duct n drilled holes for the fan n mounted the whole thing ??
[Edit]
I see u did some cutting work down there..Hmm i like ur idea tho :D.. nice work..
i will try to do the same :D
Hehe, yeah i used a jigsaw to make the hole bigger. Not the best work of all but it works just as good.
