Nice methodology Luie, I will implement it when I do my OC from now on. Thanks for sharing.
Nicks, several users have reported that 0614 is the bios that has no 1X PCIE issue. But 0604 in regards of stability, memory compatability and overall clockability of FSB is inferior to say 07xx,08xx or 09xx.
Some users said that flashing to 0614 then back to 0804, without loading defaults heplped, but manually setting all settings helped.
Also try solutions from this manual
www.altus.co.yu/temp/Q.htm (PCIE 1x issue)
Anyway I got major peoblems with soundcard software, known as soundmax panel. Yesterday I tried changing settings for microfon, beacuse it wasnt properly recognised from audio wizard. result, i got soundcard frozen, and enable to use in any program that initates sound. I couldnt close the soundmax panel either. After investigating with process explorer, i found out that the drivers of sound are diretly tied into kernel of windows. So any program I started that uses sound, lead to it being frozen just as soundmax control panel. So i couldnt even shutdown within windows. Cuase it was stuck in causality loop with windows part of windows kernel /registry. So I try to bring it down by closing handles and mutex and treads that are opened by soundmax. Result was BSOD with invalid kernel error, first I have ever seen from Windows ever. That is I think a reason why Windows works slower, has micro freeze ups, and boots a little slower. Beacuse of soundmax linking directly into kernel of OS, in a way leach links itself to the body. Any freeze up in soundmax, and that part of windows kernel is frozen too. So onboard sound is not crappy, its the software that is uber crappy. So if u find a way to get rid of it , do it without a shred in your mind.
