Sorry, my bad. Should read more carefully.
love this board :)
http://www.abload.de/img/21x200x1600x4000014plv.png
Have it working perfect with WiFi and loving it :up: Last app update must have fixed the connection issue.
http://img543.imageshack.us/img543/760/img0022yg.th.jpg
http://img403.imageshack.us/img403/2426/img0008n.th.jpg
http://img178.imageshack.us/img178/820/img0023dq.th.jpg
http://img524.imageshack.us/img524/7...g0025mm.th.jpg
http://img714.imageshack.us/img714/2...g0026jn.th.jpg
http://img121.imageshack.us/img121/6...g0030po.th.jpg
http://img214.imageshack.us/img214/6...g0032el.th.jpg
Hey guys, sorta new to the forum and recently bought a new rig that includes the rampage III extreme. I'm somewhat new to overclocking but didn't shy away from it when I had my e6300 so if anyone has any advice for me I'd more than welcome it in helping me out :)
Here's a short list of what else I got: i7 950, G.Skill PI series 3x2GB DDR3 1600, GTX 480, and a Thermalright U120Extreme since I'm gonna be running on air.
I've managed to push it to 4.08Ghz at 170bclk running the ram at 1704MHz but i've really had to loosen up the timings and apply more voltage to the ram. It seems stable after a few runs from intelburn test and prime95 but I haven't had the chance to do an extended stability test, so I know those are just a rough trial. It doesn't crash when gaming and I've been doing that more than running anything else and have absolutely no problems. I can't seem to get it much further than that. My idle temps are around 40 at idle and upwards of around 70C when under load. I can't get it to boot when I up the bclk from there, the led's right below the ram stop at DRAM when it refuses to boot on anything higher, interestingly it passes that and stops at VGA when i try 200 bclk just for fun. Here's a template of the settings I have, again I'd more than welcome any advice on tweaking the settings. Thanks.
Target CPU Frequency 4080MHz
Target DRAM Frequency 1704MHz
LN2 Mode []***
QPI Loadline Calibration []***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [24.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Disabled]
Hardware Prefetcher [Disabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualiyation Tech [Disabled]
CPU TM Function [Disabled]
Execute Disable Bit [Disabled]
Intel(R) HT Technology [Disabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Disabled]
Intel(R) C-STATE Tech [Disabled]
C State package limit setting [Disabled]
BCLK Frequency [170]
PCIE Frequency [100]
DRAM Frequency [DDR3-1704MHz]
UCLK Frequency [3749MHz]
QPI Link Data Rate [7498MT/s]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency [9]
RAS# to CAS# Delay [9]
RAS# PRE Time [9]
RAS# ACT Time [24]
RAS# to RAS# Delay [Auto]
REF Cycle Time [82]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
FOUR ACT WIN Time [Auto]
Back-To-BackCAS# Delay [Auto]
Timing Mode [2N]
Round Trip Latency on CHA ["Auto"]
Round Trip Latency on CHB []
Round Trip Latency on CHC []
WRITE To READ Delay(DD) []
WRITE To READ Delay(DR) []
WRITE To READ Delay(SR) []
READ To WRITE Delay(DD) []
READ To WRITE Delay(DR) []
READ To WRITE Delay(SR) []
READ To READ Delay(DD) []
READ To READ Delay(DR) []
READ To READ Delay(SR) []
WRITE To WRITE Delay(DD) []
WRITE To WRITE Delay(DR) []
WRITE To WRITE Delay(SR) ["Auto"]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full Calibration]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage [1.300]
CPU PLL Voltage [1.81525]
QPI/DRAM Core Voltage [1.400]
DRAM Bus Voltage [1.62975]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA ["+0mV"]
DRAM CTRL REF Voltage on CHA []
DRAM DATA REF Voltage on CHB []
DRAM CTRL REF Voltage on CHB []
DRAM DATA REF Voltage on CHC []
DRAM CTRL REF Voltage on CHC ["+0mV"]
IOH Voltage [1.21900]
IOH PCIE Voltage [1.51050]
ICH Voltage [1.11300]
ICH PCIE Voltage [1.51050]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
Thanks guys for the heads up on the WiFi. I finally gave up on Bluetooth thinking it would ever function, ended up uninstalling driver and anything blue-tooth related! I wish i could throw the darn card away without having to take out the motherboard, at least it would do something useful like free up two USB ports!. Apparently all that is required is the iPhone/iPad Mobilink V10016 installed on the PC and the latest v1007 iPhone/iPad app, which allows connectivity via WiFi :D I can't see the need for mobilink to be set in the startup group, as Mobilink runs through a service called pnSvc which monitors for iPhone connection.
Started playing around w/ the RC Tweakit utility. I must say it is pretty damn nifty. I really hope they add the ability to change multipliers and ratios in the future though. I'd never have to go in to the bios ever again.
This is the best board I've used yet; :up: running my i7 930 @ 4.3Ghz (205x21) on water. The standoffs on the EK block were a pain, but its now keeping my North and South bridges cool at around 42 degrees. Coming from a Maximus 2 Formula the overall system feels much faster (SSD drive helps here!) and games run even smoother. Got the 295 plus 250 for PhysX. Had some power up issues with bios 1005 so now on 901.
Here’s a little collage of the build at various stages;
I love the look of the black and nickel on the EK and swifty, that is a sweet combo and even sweeter rig!
My system is finally done!! All water blocks installed and no more heat!!
This rampage 3 extreme board is awesome!!
228MHz BCLK LinX stable :up: :eek:
http://www.abload.de/img/19x228x1828-2st4d.png
