One of the most original systems I have ever seen.
No pics in quotes please.
Oh! I've been following your worklog on hardwareluxx since the worklog was created but I don't know german language so I have to use the Google translate utility and that's why I don't write there. Happy to tell you here that your work it's amazing and just Beautiful.
This is the second rendition of my torture rack. Was a PITA to get the swiftech rad horizontal and there is a kink in it I have to work out. It's on the bottom, the top is actually fine.
http://i52.tinypic.com/296emxf.jpg
http://i53.tinypic.com/whf9yf.jpg
http://i51.tinypic.com/20v13it.jpg
Nice rack, reasons. Yep - that is an annoying function of the Torture Racks - they are set up for the rads DD sells - would be nice if they were more universal.
Recently completed my rig. I think I have the cooling licked... now saving up to go SLI.
http://home.comcast.net/~supercharged_z06/D800-01.jpg
http://home.comcast.net/~supercharged_z06/D800-03.jpg
http://home.comcast.net/~supercharged_z06/D800-07.jpg
http://home.comcast.net/~supercharged_z06/D800-06.jpg
I like the huge rads and the tiny little micro-res.
When I first put together my torture rack, I used 2 mcr220s. The holes simply didn't work so I turned 'em around backwards, ports out. I mounted the rads flush to the case and had barely 25mm on the interior to put the fans. I used bp rotary 90s on the rad and ran to the the mobo through the handle holes above. I also had a pump on the bottom - my second T3 actually ( I didn't trust it any where else except the bench). I ran the tubes from the pump through the back center fan hole around to the bottom 90 connected to the rads. It looked a whole whole lot cleaner than it sounds... it actually looked really clean. If you don't get that worked out, maybe give it a try.
I thank you both! I am very touched and happy that it pleases you so! (I say sorry about my bad english)
EDIT(by shazza): sonnyboy - please note that I deleted your images as the guidelines for this thread are for 4 images per case only. Since there is so much interest in your case, please feel free to make a separate post in the Liquid Cooling section or the Worklog section with a collection of your photos - we'd love to see more.
That powersupply plate is Cool ;)
http://img1.showpic.in.th/pic/c68/c6...43c05479b3.jpg
Thanks: gamethai showpic
http://img1.showpic.in.th/pic/358/35...0a5e08a661.jpg
Cast TJ-07
EVGA 285 2 G _1 PCS.
EVGA 285 1 G_ 1 PCS.
PSU TT 1500 W
Ramp II
CPU I7-920
Ram OCZ 6 G Bus 1333
Lack of light and beauty, but I sleep more at night. Then a small smile with pleasure.
paoaudit, your alu res makes me go:
http://www.youtube.com/watch?v=G-ogxxcSZhM
Kinda reminds me of http://www.mnpctech.3dpixelnet.com/p...dblog.com7.jpg ^
Link :up:
nice build, thienloi. the farthest right ramsink being shifted sticks out like a sore thumb though D:
