In-Fluence,wow thats just awesome.you've got a great chip there.
its great to see what it can do in the right board:up:
soon you might be getting some WR's
Hehe, I see you're up there too linuxfan. Nice work on 5+GHz - I'll try and get back to it at some point as my system is 2 fans down at the moment. It's been snowing here too and is freezing out so I'm tempted to get the fans running , open the windows and do a 'chilled room' run tomorrow which might help matters..
To help me on the way, I had settings saved for 535x9 and moved up with setfsb from there. What kind of volts were most of you guys using to acheive your goals? I'll post a bunch of settings of mine sometime soon when I have a nice load of saved profiles :D
I'm trying for 530x8.5 linx stable at the moment. CPU is fine but getting the NB stable is tricky. 500x9 is P95 stable. The only trouble is that I'm getting shutdowns during both - is this indicative of too low vcore or something worse?
Hey, MCH not over 1.62 will be good till 5Ghz, now PLL is another story. So you forgot your Asus yet?! :D
Great results bud :up: It does take a LOT of time and cod weather to get to sub 9.7s on Spi1m, very nice and continue to push and have fun with this extraordinary board :up:
I did not have a cherry picked, low VID chip whatsoever.
You don't WANT to know what kind of voltage I put through that CPU. :rofl:
I think I had the CPU Vcore at 1.7v in the BIOS with the MCH at 1.7 or 1.8? :eek:
Got some good scores anyway. :p:
A cold room and more vcore should help you a little to get it to around 4.9ghz for superpi. :up:
I got real lucky with the chip I think, and considering how well it clocked with low volts I thought I had a chance of getting some good max clocks. 5GHz was just out of reach on this attempt though. Eventually, the right board got me to see its real potential though and I'm very pleased :)
I didn't really try highest speed with superpi, just from the highest I used to boot with, I'll continue to have a blast tomorrow for some sub 9.5 runs. I also have a pair of reasonably speedy reapers which should help at a higher divider.
(nice colour fluid btw :D)
I'll take the MCH hint on board, thanks for that :up:
I noticed a lot of your stable runs are with really low vtt which seems to be where I fall down - I need 1.34 to keep 500x9 stable, and have gone to around 1.5v for 550+.
Totally forgot my 'Arseus' :ROTF: - it's packed away in a bow as new, ready to be sold. I'm holding out for a bit longer as I want make sure I still have a half-decent backup if I blow this board up, as the only other alternative is a P5N32-E SLI :rofl:
I've still a few things to do before I go for a run that I would consider my best attempt..
I need to lap my cpu for starters - the surface is VERY uneven. There's about 35-40% of one side that barely comes into contact with a thin layer of paste, so I have to put plenty on at the moment.
Next is to get mosfet blocks (any suggestions welcome), and maybe put in a 2nd loop to keep the CPU cooled seperately.
Finally, thanks for all the feedback - all good fun! :D
Just got 4th place in wprime 32 :D
http://hwbot.org/listResults.do?cpuM...true&limit=100
In-Fluence,congrats man.so many possibilities,and so many records to be broken.keep pushin!!!!
So, came the cold days and even cooler nights, so I finally decided to open a window and put the component on the window sills.
Wrapped in a blanket, only virila my hand was out and held the mouse.;);)
These are the achievements:
CPU-Z --> 4806 MHz
http://valid.canardpc.com/cache/banner/890533.png
wPrime 1024M - 264,687s__________wPrime 32M - 7,968s
http://www.imagesforme.com/thumb/thumb_573103d5.jpg__________http://www.imagesforme.com/thumb/thumb_3ea87f5b.jpg
SuperPi 32M-10m 51,782s__________SuperPi 1M - 9,641s
http://www.imagesforme.com/thumb/thumb_a0191d68.jpg__________http://www.imagesforme.com/thumb/thumb_8dd85f70.jpg
PiFast - 19,78s___________________3DMark03 - 66839
http://www.imagesforme.com/thumb/thumb_7583294b.jpg__________http://www.imagesforme.com/thumb/thumb_916124b5.jpg
3DMark06 - 19157________________Aquamark - 262807
http://www.imagesforme.com/thumb/thumb_ddd3158d.jpg_________http://www.imagesforme.com/thumb/thumb_5f6b9d8d.jpg
all air cooling
outside temperature was -12 C:D:D
now i go to bed
here is 5.20 AM
good night
@E-Mil:
Try Vista 64 and wPrime 2.0 and you'll get higher scores.
I meant to say this is happening during linx, and that CPU temps are hitting around 72-75°.... Any help here would be gratefully received.
@ Grisheko45
For 500x9 I used the following voltages:
vcore: 1.43125 (1.376)
mch core: 1.4 (may be able to lower)
VTT: 1.34
PLL: 1.5
CPU Reference: (one notch abover default - can't remember what this becomes)
NB Reference: Default
vDimm 1.9 (1.88)
All other voltages were left on auto.
Clock drive & skews & were set to 1000/1000/0/50 (drives may be able to go lower, but not tested) Skews were quite crucial to getting stable - make sure you try combinations to find your own best ones - for me, 100/150 worked just as well, and 150/150 seemed better for higher speeds - particularly for 540+ fsb.
I'll get around to posting a bunch of templates after I've found a few that work well for me - I've not really got any final stable settings finalised at the moment except this one, and I also have some xmas shopping to do so might be a day or so ;)
@ E-Mil - congrats on your runs! You've only made me decide to get my reapers out later on! I see you got quite a bit faster than me at lower CPU MHz, I'll have to try some of these runs in safe mode - watch this space. :D
Wohoo i can join the 4,5ghz club with my q9650 :D Just tried a 4,5 run for fun. Adjusted the vcore and the memory. And it's a 1.225VID and has gone through 2 3dmark 06's.. lol.
Here's a pic of it.. Oh it's on air, a true with a koolance fan, and a ga-ep45-ud3p rev 1.6 FD bios
http://img.photobucket.com/albums/v2...g/4500mhz2.jpg
PiFast - 1st place! I knew keeping hold of these reapers was a good idea :D
So, erm, yeh - why not join the team? Thanks for the invite, I'll gracefully accept - I'm honoured :D
Umm... thats SuperPi not PiFast :up:
Yup, totally my bad! The offending entry was deleted. I somehow was under the impression I was up for a first place as your top time was displayed as 9.6 seconds when it should have read 9.06 - I should have looked more carefully! I managed a 9.517 which got me 18th, but I wanna keep pushing, and will probably have another go in due time.
I've had a few problems due to corruption at the moment. It seems system information isn't working properly - things like mobo name not showing on CPU-Z and windows experience index not working at all, and MSinfo32.exe taking up a whole CPU until I remove it in task manager - all of which really don't help my cause. Unless I can find a quick fix - I'll probably be held back until I get everything backed up and reinstalled, but I wanna see the magic 5GHz before the hols are over, that's for sure.
I've now joined the team btw - hopefully I'll be able to contribute some goodness for y'all :D
Hi all got a question what does the CPU Clock amplitude do? its stock at 800mv here will it help me with stability and is it safe to change?
