Originally Posted by
Blasar
Hi there!!
I want to thank to WildstarOCT for his advice, i´ve tried the settings he said and the result was a nice boot :clap: :clap: :worship: :worship:
The only thing i did, for now, was to lower the CPU voltage to 1.281, and some quick tests with Prime95. Now i´ve left the CPU running Prime95 at the following settings to see if it is rock stable, if so, i´m lowering the other voltages to the minimum asap ;):
AI Overclock tuner: Manual
CPU Ratio Setting: 8X
FSB Frequency: 425
FSB Strap to North Bridge: 266
PCI-E Frequency: 100
DRAM Frequency: 1066
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO (defaults to 52)
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: Moderate
AI Transaction Booster: 8
PULL-INS: All Disabled
CPU Voltage: 1.281 :D
CPU GTL Voltage Reference (0/2): 0.630
CPU GTL Voltage Reference (1/3): 0.670
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.36
DRAM Voltage: 2.02
NB Voltage: 1.26
NB GTL Reference: 0.630
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew: AUTO
NB Clock Skew: AUTO
CPU Margin: Optimized
Advance CPU Settings
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Regards.
