really? ok i will check it.....but why would it run at 2x until the NB volts are raised? shouldnt it run at 16x at stock volts?
says 16x in cpu-z
just ran 3d05 and got another crappy score 5708
whats going on???
Except when you have to...
Or perhaps just remove some compound...?Quote:
T2k just needs to get with the times and get a D-tek.
Jesus, what kind of an uneducated urban legend BS is this... :D since when "storm is not good for quads"? BTW since when Storm knows which CPU it is on...? :rolleyes:Quote:
the storm is not good for quads.
Anyone have any ideas? From my previous post...
Wow. This makes NO sense. I just lowered my CPU voltage to 1.48, and the PLL to 1.5, and it didn't change the temp at all - it's still 54C at idle @ 3.6GHz and 28C at idle @ 2.4GHz.
Temps are confirmed by Core and Speedfan.
I'm running BIOS 901. Is it possible the BIOS temps are off by 10-15C for the OC?
there are many threads on it go look.
http://www.xtremesystems.org/forums/...torm+quad+core
the surface area of the storm is the difference.
No I dont my volts in windows via asus probe not accurate but.
vcore 1.47
NB 1.63
memory is 2.10 in bios 2.16 in probe
SB 1.06
Temps are
cpu 43
mb36
nb 47
sb 43
on load with OCCT hit 60 +
Try setting 450 x 8 and 400mhz strap @1200
just set volts for mem at 2.10v leave others auto
but change loadline enabled
Should be fine from there on in @3.6 on air or water
Try it and see good luck :up:
I DID ask others before I decided to hold on my v2 - most people said the difference is rather subtle, in the single-digit Celsius range which is nothing compared to the problems I am having right now. My current CPU temp is WORSE than it was WITH STOCK AIR COOLING which is clearly not about Storm v2 vs Fuzion, don't you think?
Other than some bored or extreme OC'er noone gives a :banana::banana::banana::banana: about 6-8C extra, I think. :cool:
PS: my main reason many years ago for going WC was to get a silent machine AND great OC performance. :)
i had a temp problem with my waterblock as well. I got the swiftech h20 220 ultra kit and i pulled off the mobo and seated the waterblocked and looked at it from 360 degrees to make sure the copper plate was actually in full contact with the processor.
I then applied thermal grease, and seated the waterblock again and securely mounted it to the mobo before mounting the mobo back into the case.
Before, i was seeing 80*C with water cooling which was ridiculous. I pulled everything off, cleaned the old thermal grease, did the aforementioned procedure, and now i'm running a cool 40*C on a 9x400 OC profile.
While under prime95 or everest, temps will go up to mid 60's to low 70's while at 100% load.
hope that helps some people
I think the grease is fine on my system given my ambient temp (in the office) is 80-81F and at idle I'm ~32C @ 2.4GHz. When it's cooler (in the mid 70's) the idle temp is ~28C.
AFAIK that's what it should be; would you agree?
What doesn't make sense is the massive spike and the fact that I had the same (above) mentioned Idle temps with my 680i, yet when I was @ 3.6GHz my idle was, perhaps 48C. With this board, it's ~56C - nearly 10C higher...
BTW what's the safe max operating temp for my 3060? Anyone know?
Hi all, I've posted a very little here about my Maximus Formula woes and it turns out it may not be the Maximus at all.
3 Video Cards and 2 Maximus Formulas have all had the same problem, so that narrowed it down the RAM and the power supply. I took out one of my 2GB G.Skill pc2-8000 sticks and viola, the system is stable again. So, it appears it was a RAM issue all along.
I see that many here on the forums are running the new G.Skill 4GB 2x2 kit without issues. What's the best test to see if this Ram is really bad? Am I simply missing some setting in the BIOS that will fix this problem without an RMA? Am I better off with another brand? The ASUS QVL list is pretty restrictive...and pretty expensive. I'd hoped to use 2x2048 so that I can expand in the future.
Thanks for the assistance.
Intel Q6600 G0
Thermalright Ultra-120 Extreme
Maximus Formula BIOS 901
G.Skill DDR2-1000 2048x2
Thermaltake ToughPower 700W
BFG 8800GT OC
Of course the Storm doesn't know, it was designed when single core processors were the norm it is an impingement design where all the cooling is directed at where the single core would be, so on a quad a core of 2 cpu's is not having and coolant put over it so therefore 2 cores run much higher temps than the other.
Also it doesn't work properly on a dual core cpu for the same reason.
Any thoughts on how to make this stable. I'm on the verge here. Boots up fine and sometimes will be OCCT stable after 1 test, sometimes itll reboot, sometimes BSOD. Anyone have some advice? So far just testing CPU..
I fully agree with what was told to you
- The Storm s**ks with quads, take it or leave it, it is a fact. The difference won't be 20°C though, of course, but it could be, depending on your setup, up to 10°C. remember, most tests used a 150W heat output. A high overclocked Q6600 will reach 220-240W... The new GTX for example was optimized for quad core CPUs
- Your Eheim 1048 is a low end competitor for the LPDC circuit you have. Coupled with your restrictive Storm WB and very restrictive BlackIce Pro, plus a MCW30 and MCW60 like it or not, you have a rather low-mid range WB circuit. Only high end watercooling can outperform high end air cooling. Even your two Eiheim in series won't make it. You'll rather need two MCP655 in series
- Finally, your BlackIce Pro will never handle massive OC, even with two Eiheim in serial, from a Q6600, MCW30 and MCW60
Many people here, with a MCP655 pump, and a PA120.3 fight with heat above 3.6GHz, so don't expect a miracle from your watercooling unless you change the pumps and the WB
Finally, suerely reseating can give you some headroom if the problem is there
Here's where you can order type 2:
http://www.pc-cooling.de/VGA-Chipset...9S+Type+2.html
They are in stock and they ship in Europe
I will be getting this board soon, and was HOPING someone can answer just 2 Q's for me...... What does "OC FROM CPU LEVEL UP" mean? and "FSB STRAP TO NB" where to set this if your only aiming for a 430FSB using PC8500 ballistix ram. Many thanks....
I'd start by comparing your setting to Renegade's.
2nd, based on other's reports in this thread, reseating the fusion block and adding water will provide much better stability with over 10C drops in NB temp. There are also plenty of links to the TR heat sinks in this thread if you must stay on air. :)
