No problem or offense taken, I didn’t take it the wrong way or anything. I don’t try to conceal or promote who I am, I consider myself just another person on the internet.
glad you are over here because the abit forum is really deficient for finding out the latest board info...this forum is a "cut" above...i haven't been back for a very long time...many times the forum was down when i tried to go to the index page...finally got tired of it being down and, for days!
anyway, this guy, HiCookie, over at OCXTREME.org is an abit enthusiasts (appears to have abit contacts) and he posted that image above...i just copied the image....here is his thread where he discusses this board and the strap info:
http://ocxtreme.org/forumenus/showthread.php?t=1025
http://ocxtreme.org/forumenus/showthread.php?t=1193
as you being a forum moderator over at abit tells me that you are a level headed individual...i respect that since i can get up on my white horse ocassionally with other posters!:p: :D ;)
stuck: Just make sure you have good temps and tested it perfectly stable. I personally would not run 505FSB 24/7 at all but YMMV. :)
Good thread, loving the board, a shocker for me, and I'm honestly considering it now because I have no need of X38, but it all depends on how well Penryn does on it.
i think the Penryn is going to be a big winner; at least the QX version...don't know about the lower level versions.
Ace-a-Rue,
Thanks for the links; I’ve never been to that site before. I’ve never seen an IP35 Pro BIOS with N/B Straps before either, now that was a surprise.
Ace this bolt mod is the truth:D
I have dropped my load temps on the PWM by an astounding 20c+...I just finished priming at 3.6:450FSB@1080 DDR2 for 8.5 hours...I just wanted to say thanks:D:D
cheers,
h
the bios doesn't actually show you the NB straps persay...it is just shows the FSB to Memory ratios...i believe either Hicookie or onepagebook took the image of that bios section and super-imposed the NB strap info that he apparently received from Abit engineers...SO...you will just see the 1:1, 1:1.20, and so forth...the user just has to know the first two FSB to Memory ratios settings are for the 1333 memory strap; the 2nd two are the 1066 strap settings.
it is the reason why the board clocks higher in the FSB side when using the 1333 strap settings.
The second post at the first link you provided has a screen shot of an early pre-release BIOS with selectable N/B Straps.
http://ocxtreme.org/forumenus/showpo...44&postcount=2
I know this is off topic but does anyone know these measurements of the mounting holes for the
northbridge please?
Pin to pin is 58mm
Didn't square it off like your picture. Btw the std chipset cooling is good enough, just add a fan.;)
Does this board support 1066 memory I have Crucial 4X1 GB Ballistix its there kit# bl2kit 12864aa1065.000
This is the memory I want to use
yup,but read and run as 800. So does my pc9200
Ace-a-Rue--> I just flash my board w 14 bios but not pleased with it. When i flashed back, suddenly it restarted itself and stuck at C1 post code. I have 2 hot swap it and reflash w 11 bios.
But the problem is now bios doesnt detect my core temperature. Have u experience such things?
yep. i've tried them all ,except the battery thing, but it wont worked.
Im not sure its gonna work, beacause some people in indonesia have experience the same thing when they flashed back to 11 bios from 14 or 16 beta. But I'll try it anyway.
Thanx
8K????...wholly-mackerel!:D
5 dolla make ya holla:D
