does that graph counts for the 165 to? i thought 170 only.
Man now if that graph counts for my 165,i am ready to kill a :horse: :D
Absolute, here is mine --> batch is #562Quote:
http://img53.imageshack.us/img53/4879/3ghz12h0nt.th.jpg
Do you pop popcorn on you HD :D
168 & 523, both can do 10x300 or 11/273 (2Gmem on 523) so far. Says 1.3... on bios (liars, DMM says 1.45-1.48)
Rosetta Stable.
I just downloaded the latest Tcase, and my Opteron 170 reading is 53 C. Previously, Tcase showed a reading of 49 C like was previously posted. Could someone clarify what the Tcase reading means, and if/why it is important?
On my 165 it said 49C... but there were no issues when I hit 51C (as high as it ever wnt)Quote:
Originally Posted by kberguy1
I really dont think its very useful.
Case TemperatureQuote:
Also called Tcase Max within AMD processor datasheets, this value indicates the maximum temperature the processor case is allowed to reach and remain within recommended operating temperature.
Taken from http://www.amdcompare.com/us-en/glossary.aspx
hmm.... and it can go up??
Awesome man! :woot: :toast:
quick question what did you set bios to, to get 1.568?
Umm...can anyone please guide me a bit?Quote:
Originally Posted by xfachx
And nice oc'ing everyone!
I wouldn't think so... Probably the program has been updated to handle optys better?Quote:
Originally Posted by CompGeek
Guys I never tried to lower volts before
so last night
2.8GHZ, only 1.29V, dual prime stable six hours plus :D
I know once I get the peltiers cooler this will be a 3ghz chip too when I can make voltage = 1.5~1.55 :banana:
proof: :fact:
http://img293.imageshack.us/img293/1601/26te.th.jpg
2GB, 250-270 FSB, 2.6Vdimm -newegg
Originally Posted by ceevee
What was your load temps with that Zalman?
So, I can prime each core at 2950Mhz, but not together. Possible heat issue? Temps are 52C. Just couldn't wait for water... :P
Definately heat...at that frequency you should stay under 45C..voltage will not do you any good .Quote:
Originally Posted by thunderstruck!
@ Grinch, 1.55 + 104%
@ Thunderstruck, definitely heat, 52cload makes VPMWs cry, get them cooler.
Load temp is 43C with the Zalman at stock volts
-can't go much higher frequency right now because temp problems develop quickly
I have a fear of razor blades, or at least of razor blades that make costly mistakes:) . Is it possible that the silicone sealant holding the IHS on my Opteron 170 would disolve if the processor was soaking overnight in it?Quote:
1 sure way to find out.....nike that thing....just do it! :toast:
Try also different drivstrengths.. That helped on my previous OPTY. try the different settings and see if there is any improvement!Quote:
my new 0550 VPMW 50393 batch all air cooling default vcore 2800mhz :toast: still testing.... http://img468.imageshack.us/img468/1...shot0025er.jpgQuote:
Quick question before I upgrade.
I have a Venice 3000+ at 2.6ghz (1.55volts :( ). Am I pretty much sure to get at least 2.6 on a 165?
Yeah, even the worst 165 should do 2.6, but of course no guarantees. I think with decent cooling, you should be able to hit over 2.7 Ghz 90% of the time.
Course that's decent cooling, decent PSU, decent mobo, etc.
That's what I think after reading parts of the thread. I guess I can't go wrong considering I pay nothing for the upgrade.
times i wish I had water.
My memory has a lot to do with it also. If i keep my memory at 200mhz with loose timings, i can be stable at 3gighz.
If i do 2-2-2-5 @ 250 w/ cpu at 3gighz, then it fails prime.
right now I am rock stable at 2900 w/ 2-2-2-5/241mhz
Heat is killing me. No matter, I am off to yonah-land anyway.
