Originally Posted by
Hooker
Like I said in previous posts, I did. And this isn't the first time I've set-up a RAID-array, so I know the basics pretty well ^^. It's also an OEM-disc, no altered settings, drivers or added stuff. Just the stuff Microsoft put on there. (and yes, both Vista32 and Vista64 are the same).
I'm not pushing F6 (you don't need to in Vista), the installer itself prompts me to install drivers, way before you have to select the destination drive. That should come after you put in your productkey, this happens before I enter my productkey.
I'm going to try what Backlash said, using port 0 & 1 and disconnect every other SATA device, I'll disable the Marvell controller as well during the installation. Not the way I want to setup windows but I'll try anything at this point. I'll report back, hopefully from a functioning PC :(
