No overclocks are guaranteed, even some VPMWs have trouble doing 2.8-2.9. And poor Nealh's barely does 2.7.
EDIT: if you were referring to Grinch's post 3099 those are an 0546XPMW
I know =\
Course, it seems everyone with a VPMW that doesnt do well has high temps.
wish ida got a vpmw instead of this upmw
there flying..
Ima end up with a UPMW I beleive... may sell it depending on results.
VPMW overclocks seem to have a lot to do with controlling temperature.
mine does just fine at 1.35V 2.8ghz, but increasing much more than that and I get heat problems (50C full load)...
take my results with a grain of salt this was my first time to build a pc :)
Absolute, does the chart you are compiling control for cooling solution used? It seems like if this variable is not controlled for it will have a much larger influence on reported results than batch
I just want 3ghz.... willing to push to 1.55v for it, but I'd rather 1.45-1.5
Or like the lucker Absolute0, 1.4v :bs:
SameQuote:
Originally Posted by CompGeek
Anone still selling these retail vpmw's?
I might just have ti snatch up on one..
Dunno, Im all over one as soon as Dave @ Flickerdown gets any.
Originally Posted by ceevee
Yes, i list all the CPUs, cooling, load temps, voltage, and max stable clocks. And then i rank them. And based on the ranking, i give them points. Let me show you the chart
This is UNBELIEVABLY ghetto, i apologize, but this is quite a few results ranked... afew of them are kind of off, for example Grinch's 0358 i marged into the 035x because they were about the same, but i forgot that was before he removed the IHS, nevertheless the trends are similar.
http://img.photobucket.com/albums/v7...l/097ace93.jpg
The biggest trend is that right after the worst chips, is a good one.
I'd like to know what this is all about? I got a good chip, lucky or not, i am tired of you whining about it in every post you make that you know i'm liable to read. Just stop trying to compete with me, stop trying to confront me, stop trying to whine/argue with me, i'm done with it.
Jealousy, thats all :toast:Quote:
I have 8 pts! Btw absolute, what batch # are you and how far on stock volts did you get?
The only ones that got 8 pts are mine and Rufus'
My stock volts is 1.31, it's fully prime stable at 2.9 on 1.31 with watercooling, now with the IHS removed it might do a little more like 2.92 with 1.31
Absolute, did I ever mention how lucky you are?
jp with ya dude, hope my 170 can hit 3ghz, albeit at higher voltage.
I just went by batch #. I have a 0154 iirc.
jeje, to much talk here...now go and do that 3.2 primer:stick:Quote:
..attending classes and such, all is just in the way here...:slap:
Before I went to sleep I had hopes for a excellent 3.2'er waiting in the board for my breakfast reading...but nono, nothing here.
Bad boy, baaaad boy:slapass:
hehehe, I just know I got some :slash: coming my way now...
Eh it's been running Rosetta. I'm doing physics. Maybe 3.2 tonight maybe not.
Reserve this post for 3.2 action... sometime :P
Gentlemen - start your engines! Priming at 3.2 with 1.55v ;)
:toast:
Take thisQuote:
Originally Posted by Clint
FX60 OWNED
http://img.photobucket.com/albums/v7...l/d529caf7.jpg
well, post the screenshot already. all 42:43 of it:D
edit:nvm, beat me 2 it
congrats absolute thats amazing, not too crazy volts either :toast:
Same as mine, is it only the later steppings ware core 0 is weaker generally ?Quote:
Originally Posted by thebeast
Thats a MAJOR Kickass clock!!!!:woot:Quote:
Ok my opteron 165 (CCBWE 0602BPMW) now with ihs removed doesnt go any harder then 2665mhz stable @ 1.45volt,also higher voltage doesnt help me because the temparature goes to high.
If i play games like battlefield 2 the temp is +-40 celsius.
With prime is goes to 50-53 celsius :stick:
I think i go check the contact between the core and the zalman 7000 fullcopper,i havent modified anything for this because i think it makes contact?
Or must i modify something :confused:
Best graph ever! LOLQuote:
Congrats, mate. Hell of chip you got!
