X48 Rampage Formula Preview
OH GREAT thats all I need another board .
Thanks for the info though
I built one of these boards a few weeks ago and it was fine no probs at all.
Dont suppose it could be a ram compatibility issue ??? the ram is a few years old now.
Bios rev.902 - Will it solve my boot priority problem?
I have a RAID 0/1 arrays set up on two disks for my Vista 64 OS under Intel Matrix Storage.
I am trying to connect a Sans Digital Tower Raid TR8M. I installed the bundled (Port Multiplier) controller PCIe card and its driver under windows vista64
the card & drivers are recognized and funcitoning properly according to Device Manager.
In Bios (when TR8M IS connected) - under Boot Priority my choices are limited to:
#1 - RAID: 0:4:00-0WDC WD15EADS
#2 = CDROM
#3 - DISABLED
#4 - REMOVABLE DEVICE
I can not find any option in Bios which might (for instance) change which RAID array appears in #1. As shown above #1 is the TR8M controller card. It is automatically inserted as the "default" boot RAID array, and since there is nothing on it I am unable to boot. The TR8M "highjacks" the "boot from RAID" arrary option.
In Bios (when TR8M is not connected - under Boot Priority my choices are:
#! - RAID: WDVISTA
#2-#4 are the same as above
#1 in this case is my origianl Intel Matrix Storage managed boot array, which is the one I need to boot into Vista64.
Responses from manufacturer:
The problem is on the ASUS Rampage motherboard boot sequence. Please try update the ASUS BIOS and then make sure boot sequence on both Hard drive field and Add-on Adapter. You can also check if there is any disable function to disable the boot from the Add-on card.
The boot sequence is always handled by motherboard. The card does not hijack or do anything to modified your BIOS setting. In other word, the card only tell the BIOS that the card is installed. It is up to BIOS to use it as boot or not. That is why updating BIOS may resolve/help your issues.
Disable add-on card is mostly under boot sequences. BIOS implement differently so I cannot pin point to the location for you.
My question to the knowlegeable is: my current Bios is 803; will an update to 902 solve my problem as the manufacturer sugggests? Or is there a setting/solution that I am missing.
Thanks in advance.
Note current setting: Bios Main - SATA Configuration - Configure SATA as [RAID]. Should this be set to AHCI? Would that solve the problem? Can I change it after my Vista64 had been installed on Intel Matrix Array?
First OC attempt with Rampage Formula
Hi everyone,
After my IP35 Pro crapped out a couple weeks ago, I replaced it with a Rampage Formula that I acquired new for a mere $140 because of the board's age. I had my e8400 at 4.05 GHz on the P35 board, and I'm shooting for something a bit higher on x48.
Currently, I'm at 460 FSB, 1.3vCore, 1.31 vNB, 1.24 vTT, 1.52 vPLL, and 48-49c max under OCCT load with a Mugen 2. My GTL ref voltages are .63 for both the CPU and Northbridge. I idle at 40c, but I believe that's inaccurate due to a stuck temp sensor; when I'm at 2% load, speedstepped down to 6x, I still idle at 40.
Anyway, 460FSB is completely stable at relatively low volts.
But when I try 465FSB, I get errors even at 1.35vCore, 1.41vNB, etc.
I'm using PC8800 G.Skill PI memory, so I know that's not the bottleneck.
Any thoughts about breaking this FSB wall? With a dual core, I've read that the Rampage Formula should be capable of 600FSB in extreme cases, although 500FSB would be great IMO.
Thanks.
